| Register | iSpy | Wiki | All Albums | gXboxLive | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| This is the place to discuss everything related to Top Gear, Fifth Gear, and more! However, to gain full access to these forums, you will need to register. As a registered member, you will be able to:
All this and much more is available to you absolutely free when you register for an account, so sign up today! If you have any problems with the registration process or logging into your account, you can contact us. Already have an account? Login to the upper-right to hide this message and all advertisements on the forums. | |
| General Automotive All stuff relating to cars, trucks, motorcycles, etc. that don't fit in the categories below. |
| | LinkBack | Thread Tools | Search this Thread |
| | #41 |
| You still moderated yourself. You said you thought diesels would take over, and that will not happen as long as people like myself are around. ![]()
__________________ Jeremy Clarkson's Online Articles | |
| | #42 |
| Joined: Jul 27th, 2004 Last Online: March 18th, 2007 Location: G?teborg, Sweden / Mainz, Germany Posts: 129
Rep Power: 0 ![]() | Yeah, you petrol talibans are hard to exterminate ![]() ...but your day will come, mark my words ![]() |
| | #43 | |
| Joined: Jun 25th, 2004 Last Online: January 26th, 2005 Location: France Posts: 256
Rep Power: 0 ![]() | Quote:
* variable air intake, sometimes continuously so; * variable intake/exhaust valve timing and/or lift; * compression ratio increase; * twin scroll turbocharging; * Valvetronic; * direct injection Diesels? Direct injection has been in truck Diesel engines for decades. The only real innovations are Common Rail (Fiat, Magnetti Marelli), pump nozzles (VW, Bosch) and variable vane turbocharging.
__________________ There are 10 sorts of people. Those who understand binary, and the others. --- Weight is everything. Power is just an accessory. | |
| | #44 |
Rep Power: 0 ![]() | Exactly what you said there about the petrol engines is quite interesting, idletask. A lot of effort has been put on the petrol engines the last 10-15 years (VTEC and stuff like that), while there hasn't been much progress on the diesels. I think this tells that the petrol engines are beginning to reach their maximum (agh, I'll probably regret saying that in the future, but ), but there's probably a lot more work to do on the diesels. Just look at BMW and Honda's latest diesels...they're pretty damn good.I think petrol will still be the choice for conservative supercar makers (read: Ferrari) but makers able to see past the diesel exhaust fumes might find that it has got a lot of potential? |
| | #45 | ||
Thing is, petrol needs to reduce consumption, and the only good way that has been thought of and applied right now is stratified injection. Works great in Japan, it's been working there for more than ten _years_ now, but their fuel is much higher quality than anywhere else in the world. Stratified injection means you have lean spots in the air/fuel mixture, which generates NOx. NOx traps exist, but sulfur kills them! And BTW sulfur is also one of the main factors of particulate generating (Diesel soot!). Quote:
And petrol engines _do_ emit particulates too, but they are way thinner than Diesel ones because of the different chemical composition of these two fuels. edit: fix typo
__________________ There are 10 sorts of people. Those who understand binary, and the others. --- Weight is everything. Power is just an accessory. | ||
| | #46 |
Rep Power: 0 ![]() | Oh...you know a lot more on subject than me ![]() By Japan, do you mean for instance Mitsubishi's GDI engines? I've read that they have kind of a particle emitting problem? |
| | #47 |
| Joined: Oct 25th, 2004 Last Online: January 2nd, 2009 Location: Egyptian living in Redmond, USA Posts: 1,618
Rep Power: 19 ![]() | I can't believe you guys are having this diesel vs petrol discussion in 2 threads at once ![]()
__________________ .
| | #48 | ||
![]() Quote:
As a result, in other countries, GDI engines as well as similarly functioning engines from PSA, VW/Audi, Ford and BMW work with stoechiometric air/fuel mixtures and in fact don't use stratified injection at all. But they will once Japan quality fuel reaches the rest of the world ![]() This same sulfur BTW is the reason why the E320CDI now on sale in the States is only 48 state legal... Had Diesel fuel been the same quality as we have here in Europe, it would be emissions legal even in California ![]()
| | #49 |
| heheh, my car is a petrol-diesel! It only revs to 5000RPM and has tons of torque, but no hp, yet it still does 0-60 in 8ish seconds (not bad for only 121hp and 19 years old) I would probably buy a 535d instead of a 545i cuz you can make them perform better for a lot less. ie: bigger turbos, remapped software, etc. And in daily driving, it is not always necessary to rev to 9000 rpm or whatnot. PS: anyone ever heard the noise that the x-raid X5 Dakar makes? Its sounds soooooo nice. (3.0 diesel -- 3rd overall in 2004 Dakar, would have come 1st except for a crash.)
__________________ ![]() ----------- 1986 325 ----------------------------------------------------------- 1987 325ic ----------- | |
| | #50 | |
Rep Power: 19 ![]() | Quote:
![]() j/k
| | #51 | ||
| Quote:
__________________ ![]() ----------- 1986 325 ----------------------------------------------------------- 1987 325ic ----------- | |||
| | #52 | |
| Quote:
__________________ Jeremy Clarkson's Online Articles | ||
| | #53 | |
| .sa = bad driver! | Quote:
| | #54 | ||
| Quote:
