+ Reply to Thread
Page 2 of 2
FirstFirst 1 2
Results 21 to 37 of 37
Thread: Could regular fuel be better then premium?
  1. #21
    M_Bolc's Avatar
    Aug 31st, 2006
    San José, Costa Rica
    M_Bolc has between 1500 and 1999 reputation M_Bolc has between 1500 and 1999 reputation M_Bolc has between 1500 and 1999 reputation M_Bolc has between 1500 and 1999 reputation M_Bolc has between 1500 and 1999 reputation M_Bolc has between 1500 and 1999 reputation M_Bolc has between 1500 and 1999 reputation M_Bolc has between 1500 and 1999 reputation M_Bolc has between 1500 and 1999 reputation M_Bolc has between 1500 and 1999 reputation M_Bolc has between 1500 and 1999 reputation 31
    Quote Originally Posted by Das_Idiot View Post
    (...) designed for 87 octane and using higher octane fuel can cause other issues.
    Actually, higher octane than required won't do any damage.
  2. #22
    Square with a title wooflepoof's Avatar
    Jul 18th, 2005
    Texas, but I go to school in RI,Canada
    wooflepoof has shifted into fifth gear! wooflepoof has shifted into fifth gear! wooflepoof has shifted into fifth gear! wooflepoof has shifted into fifth gear! wooflepoof has shifted into fifth gear! wooflepoof has shifted into fifth gear! wooflepoof has shifted into fifth gear! wooflepoof has shifted into fifth gear! wooflepoof has shifted into fifth gear! wooflepoof has shifted into fifth gear! wooflepoof has shifted into fifth gear! 109
    My friend who enjoys wasting his parents money ONLY puts Shell Vpower in his Corolla when he can. Otherwise nothing less than 93 will do. Hes also the kid that curbed our friends Mazda 3 claiming he 'oversteered' and hit the REAR RIGHT TIRE on a RIGHT HAND TURN in a MAZDA 3. We humored him cuz it only resulted in a flat. But I digress
    my cars book recommends 91+ but it says it can take 87. I've tried all 3 and there's a noticeable difference between 87 and 91 but not 91 and 93.
    I guess you just can't trust a German.
  3. #23
    Mrs. D-Fence IceBone's Avatar
    Jan 14th, 2007
    Slovenistan
    IceBone has a jaaaaaag worthy rep IceBone has a jaaaaaag worthy rep IceBone has a jaaaaaag worthy rep IceBone has a jaaaaaag worthy rep IceBone has a jaaaaaag worthy rep IceBone has a jaaaaaag worthy rep IceBone has a jaaaaaag worthy rep IceBone has a jaaaaaag worthy rep IceBone has a jaaaaaag worthy rep IceBone has a jaaaaaag worthy rep IceBone has a jaaaaaag worthy rep 278
    My car has a Direct Injection system with very high compression, so needs 95+ octane, but I've found that I get better fuel consumption (more than enough to counter the price increase) if I tank up on 98 or 100.
    Bridge to Gantry time: 11:07
    Too pervy for the NSFW section.
  4. #24
    Can't Start His Wank argatoga's Avatar
    Oct 4th, 2005
    Washington State, USA
    argatoga has a jaaaaaag worthy rep argatoga has a jaaaaaag worthy rep argatoga has a jaaaaaag worthy rep argatoga has a jaaaaaag worthy rep argatoga has a jaaaaaag worthy rep argatoga has a jaaaaaag worthy rep argatoga has a jaaaaaag worthy rep argatoga has a jaaaaaag worthy rep argatoga has a jaaaaaag worthy rep argatoga has a jaaaaaag worthy rep argatoga has a jaaaaaag worthy rep 370
    Both my cars get 87 (US) octane, (yes even my 182hp per liter MG gets the basic stuff).
    "If you think about it breast implants aren't much different than braces. Their main purpose is to improve one's appearance, at least that's how it was in my case." - KaJun
    "Anyway, I'm off to eat my dick" - Austere
  5. #25
    Das_Idiot's Avatar
    Jul 20th, 2008
    Tulsa, OK
    Das_Idiot is idling in neutral 7
    Quote Originally Posted by M_Bolc View Post
    yeah I mean lower, not higher. If you use lower octane than what's required you can get early combustion of the fuel which most people know as 'knocking' and this is bad, mmkay.
    but you are correct, using higher octane fuel won't do any damage to the engine, it just won't give any benefit either as the compression ratio is so low in these cases that you won't get any benefit. You do however get to spend more money for what (to you) amounts to the same thing... and some people are weird/stoopid like that.
    and no, higher octane fuel won't 'burn cleaner' or anything like that. (whatever the hell that means).
  6. #26
    Sep 18th, 2008
    Turku, Finland
    difiCa is idling in neutral 7
    Wouldn't it be exactly the opposite? I mean, if higher octane fuel can resist burning in a low compression engine so well that it combusts only partially, leaving finite amounts of it behind, wouldn't that count as "burning dirtier"?
  7. #27
    Jan 14th, 2007
    Slovenistan
    There's a difference between autocombustion from excessive pressure (which a higher octane rating prevents) and assisted combustion, i.e. using spark plugs.
  8. #28
    Stefano1337's Avatar
    Jun 3rd, 2008
    Germany
    Stefano1337 is idling in neutral 8
    Isn't it true though that if you put normal petron in your car after you have filled it up with optimax or something, your engine management might get confused?
    Strebsam doch Blödsinn.
  9. #29
    Spectre's Avatar
    Feb 1st, 2007
    Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep 344
    At least over here, sometimes higher octane fuel "burns cleaner" because they have a much larger percentage of detergents in them. Nothing to do with the actual petrol, it's the additive package.
    Enough is enough.
    We are not here to subsidize your clueless business plans or reward your failures.
    1986 Honda Nighthawk 700S (project, light restoration in progress)
    1987 Jaguar XJ6 Series III Vanden Plas (modified)
    1990 Nissan (WD21) Pathfinder SE 4x4 (little red offroad commuter box)
    1995 Jaguar (X300) XJR
    1998 Honda Pacific Coast PC800 (two-wheeled pickup truck/utility bike)
  10. #30
    2 Slow 2 Noisy MattD1zzl3's Avatar
    May 6th, 2007
    Miamishire
    MattD1zzl3 has shifted into third gear MattD1zzl3 has shifted into third gear MattD1zzl3 has shifted into third gear MattD1zzl3 has shifted into third gear MattD1zzl3 has shifted into third gear MattD1zzl3 has shifted into third gear MattD1zzl3 has shifted into third gear MattD1zzl3 has shifted into third gear MattD1zzl3 has shifted into third gear MattD1zzl3 has shifted into third gear MattD1zzl3 has shifted into third gear 0
    So me running down to murreys and getting that 5gallon drum of 118 octane is a waste of money than?
    Remember, you are talking to a guy named "Matt" who drives a 4th gen Camaro, thinks the LT1 is mans gift to speed and has "D1zzl3" in his username. ~thedguy
  11. #31
    Spectre's Avatar
    Feb 1st, 2007
    Race gas is another creature entirely. Everyone here is talking about pump gas.
    Enough is enough.
  12. #32
    May 6th, 2007
    Miamishire
    118 + Camaro = Surrounding Air smells like jesus.
    EDIT: I can get 110 from the pump here in florida, nyah nyah nyah nyah.
  13. #33
    Spectre's Avatar
    Feb 1st, 2007
    I can get 120, what's your point? Its still not "normal" pump gas.
    Enough is enough.
  14. #34
    May 6th, 2007
    Miamishire
    O.o 120 from a normal chain gas station? TEH?!?!?
  15. #35
    Spectre's Avatar
    Feb 1st, 2007
    There's a Sunoco Race Fuels station nearby and if that wasn't enough, there's a damn airport.
    Enough is enough.
  16. #36
    Jul 18th, 2005
    God Bless Texas
  17. #37
    May 6th, 2007
    Miamishire
    haha, ill convert a car to run on avgas one of these days...
+ Reply to Thread
Page 2 of 2
FirstFirst 1 2
  1. Replies: 12
    Last Post: December 6th, 2007, 1:23 PM
  2. Xbox 360: Premium vs Elite
    By Ottobon in forum Entertainment
    Last Post: June 19th, 2007, 11:36 PM
  3. Comparison : Premium convertibles
    By SL65 in forum Magazine Reviews
    Last Post: February 1st, 2007, 11:42 PM
  4. Outback 2.5i Premium or Forester XT
    By nitrosubaru in forum General Automotive
    Last Post: August 21st, 2005, 3:03 PM
  5. supercars.net premium access?
    By justin syder in forum Off-Topic
    Last Post: September 10th, 2004, 4:41 PM
