View Poll Results: Which is a better power upgrade?
Voters
47. You must log in to vote in this poll
  • Supercharger
    11 23.40%
  • Turbo
    28 59.57%
  • NOS
    1 2.13%
  • other
    3 6.38%
  • Rocket motor
    4 8.51%
+ Reply to Thread
Page 3 of 3
FirstFirst 1 2 3
Results 41 to 47 of 47
Thread: Power Upgrades
  1. #41
    AutoMX's Avatar
    Oct 3rd, 2004
    Los Angeles
    AutoMX is idling in neutral 0
    super + turbo = "twincharged"
    There's lots of twincharged car, normal ones, not high end turner cars. It's a fairly standard procedure like installing a turbo, but you put in a SC too. The result is low end torque and high end revs/torque. The downside is you lose a bit of efficiency on both ends (a little less low end SC power and less top end revs because of the SC). Fairly standard yes, but not easy by any means.
    http://shell.deru.com/~sgn1/AW11/mod/gsa.htm
    Mar 13th, 2005
    Melbourne, Australia
    jneil is idling in neutral 0
    Supercharged does not necessarily mean more torque than a turbo low down.
    Here is recent Dyno overlay of the same 5.7litre LS1 powered car with his old 7psi Vortech Supercharger vs his new 7psi SINGLE Turbo setup.
    Same peak top end power, but HEAPS more torque from idle!
  3. #43
    May 26th, 2004
    hong kong
    jasonchiu is idling in neutral 0
    do super chargers have bov's?
  4. #44
    Mar 13th, 2005
    Quote Originally Posted by jasonchiu
    If you rephrase the question to "Can Superchargers have bov's?" then my answer would be "Yes, if you want them to".
    I would guess and say that they generally run quite low boost which is why most don't.
  5. #45
    Dr. Woo's Avatar
    Jan 3rd, 2005
    Georgia
    Dr. Woo is idling in neutral 23
    Turboooooo!
    May 26th, 2004
    hong kong
    tight bov sound so good
  7. #47
    "bangle for president" bone's Avatar
    Jan 14th, 2004
    belgium!!
    bone has shifted into fifth gear! bone has shifted into fifth gear! bone has shifted into fifth gear! bone has shifted into fifth gear! bone has shifted into fifth gear! bone has shifted into fifth gear! bone has shifted into fifth gear! bone has shifted into fifth gear! bone has shifted into fifth gear! bone has shifted into fifth gear! bone has shifted into fifth gear! 86
    a turbo does have a BOV becaus it keeps spinning after the engine has decellerated. but since a supercharger is propelled by a belt connected to the engine, this problem doesn't arrise
+ Reply to Thread
Page 3 of 3
FirstFirst 1 2 3
