+ Reply to Thread
Page 3 of 6
FirstFirst 1 2 3 4 5 ... LastLast
Results 41 to 60 of 103
Thread: Rotary Engine discussion
  1. #41
    Lazier than Viper Renesis's Avatar
    Nov 27th, 2003
    Quebec, Canada
    Renesis is idling in neutral Renesis is idling in neutral 36
    Yeah they burn oil, that's normal it's a seal lubrication process
  2. #42
    M5Rangerover's Avatar
    Jan 27th, 2004
    Edmonton, Alberta
    M5Rangerover is idling in neutral 0
    seems kinda wasteful to me
    and synthetic oil aint cheap!
    ----------- 1986 325 ----------------------------------------------------------- 1987 325ic -----------
  3. #43
    Nov 27th, 2003
    Quebec, Canada
    Well it's better than seals cracking ($$$ repairs)
  4. #44
    Jan 27th, 2004
    Edmonton, Alberta
    i guess, it just seems odd that a manufacturer would build a car that needs that
  5. #45
    Nov 27th, 2003
    Quebec, Canada
    I feel the same way about pistons....
    ZING!!!!!
  6. #46
    Jan 27th, 2004
    Edmonton, Alberta
    LMAO
    we all have our own opinions
    some just more weird than others
  7. #47
    Nov 27th, 2003
    Quebec, Canada
    obviously I was joking but the occasion was too good to pass on, I couldn't resist!
  8. #48
    gaemon82's Avatar
    Jun 10th, 2004
    Somewhere in northern Italy
    gaemon82 is idling in neutral 0
    Well I am glad that both kind of engines still exist, because they are both fascinating. The smoothness of the rotary engine is extrordinary (took an RX8 for a test drive yesterday). But I also like piston engines, just listen to the noise of the BMW M3 CSL or an Alfa GTA engine, fantastic, proper racecar sound. Both engine concepts have their advantages and disadvantages (as for reliability on a piston engine, well, I did over 300,000 miles in my old car and never had an engine problem, nothing at all).
  9. #49
    Nov 27th, 2003
    Quebec, Canada
    agreed
  10. #50
    Likwid's Avatar
    Jun 2nd, 2004
    Likwid is idling in neutral 0
    One of my friends has an 87 RX7 Turbo II and an 88 RX7 GTU. They really dont use that much oil.... nothing that would be a burden as far as maintence costs at least.
  11. #51
    zyran's Avatar
    Mar 21st, 2004
    Malaysia
    zyran has negative reputation 0
    Yeah the 'M' flash apparently fixes the flooding issue (you can't see any topics about flooding anymore) and improves gas milage. Not too shabby.
    Jun 2nd, 2004
    Atlanta, GA
    RussTypeS is idling in neutral 0
    Quote Originally Posted by off/lang
    Flooding is an issue of the RX-8, but there is doubt as to whether it is the rotary engine in general that is causing it. Many people think that it is actually a bug in the ECU. In fact, Mazda released a patch to the firmware (version M) and so far nobody (on RX-8 Club at least) has reported flooding with the M patch, so it seems to be something that was solved.
    i take it you have never owned another rotary. they are extremely prone to flooding. they always have been. the first gens (rx-7) had to be fully warmed up once started. if you turned it off before it was warm you risked flooding every time.
  13. #53
    Jun 2nd, 2004
    Atlanta, GA
    oh yeah, about the oil issues.
    its not like rotaries burn oil due to bad design. they have a pump that injects oil into the combustion chamber. there is really no other way to lubricate the side seals. its really not THAT much either. hell my astro van burns more oil (or leaks it all over my driveway).
    and forget synthetics in rotaries. i use castrol gtx in my race motors, burns clean and works great.
  14. #54
    May 17th, 2004
    London - Islington
    Synaethesia is idling in neutral 0
    rotary engines are much more prone to wear then piston based ones and so oil is needed to keep things running friction free around the corners of teh cumbustion chambers where there is contact (see Renesis avatar)
  15. #55
    off/lang's Avatar
    Jun 13th, 2004
    MSP/PVD
    off/lang is idling in neutral 0
    Quote Originally Posted by RussTypeS
    True, this will be my first rotary. But I would still argue that it is more of a mazda bug than a defect in the generic rotary design. (How else could a software upgrade really fix it?)
    What I've heard is that the ecu was misreading the temperature sensors in certain conditions and starting up with to rich a mix, thus causing it to flood.
    Audi A3
    dearinter.net - consensus life coaching
  16. #56
    dukenukem's Avatar
    Mar 9th, 2004
    Fort Worth, Texas
    dukenukem is idling in neutral 0
    how do you guys like my new avtar...its a Wankel
  17. #57
    justin syder's Avatar
    Dec 8th, 2003
    New York, USA
    justin syder has shifted into first gear justin syder has shifted into first gear justin syder has shifted into first gear justin syder has shifted into first gear justin syder has shifted into first gear justin syder has shifted into first gear 35
    looks like a washing machine without clothes and the shell put on rinse cycle.
    "I’ll sock you in the goddamn face and you’ll stay plastered!"
    -William F. Buckley Jr.
    Ich Fahre Deutschen, Ich Fahre Mercedes-Benz.
  18. #58
    dukenukem's Avatar
    Mar 9th, 2004
    Fort Worth, Texas
    ^^ dont diss the wankel.....or the rotary god will condemn you to eternal damnation
  19. #59
    Nov 27th, 2003
    Quebec, Canada
    nice avatar! a bit jerky when it reatarts but it's cool nonetheless! 8)
  20. #60
    Jan 27th, 2004
    Edmonton, Alberta
    i followed an RX8 today... interesting sound.... nothing quite like it... I'm not quite sure if I like it yet
+ Reply to Thread
Page 3 of 6
