| Register | iSpy | Wiki | gXboxLive | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| General Automotive All stuff relating to cars, trucks, motorcycles, etc. that don't fit in the categories below. |
| View Poll Results: Can you drive clutchless in your manual? | |||
| Yep. |
51 | 45.13% |
| Nope. |
43 | 38.05% |
| I drive an autotragicmabox 5000. |
19 | 16.81% |
| Voters: 113. You must log in to vote in this poll. | |||
LinkBack | Thread Tools | Search this Thread |
#41 |
There really is no reason to shift a modern synchro tranny clutchless, it's just for the novelty of it.
#42 |
Last Online: 3:16 AM
Car: Fabia vRS (180bhp/312lbft)
I perfected the art whilst trying to destroy a rented Vauxhaul Corsa (see the Worst Car Driven thread) but the bugger still refused to die. No need for it normally, but the ability to do it came in handy when the slave cylinder went on my old VW Corrado. I always rev-match for seamless changes with the clutch anyhow as I drive very hard especially 'round corners, so need to keep the flow of the vehicle smooth and not upset the balance.
#43 |
Yup, had to do it when my clutch's master cylinder gave out and I was stuck with a clutch pedal stuck 2mm off my firewall....
#44 |
^ will bore you to death
If I build a lemons car I may try, but I won't risk the destruction on my transmissions. Doing upshifts without the clutch is just asking for a broken layshaft.
I also don't shift particularly fast on either of my cars, as I know syncros need a moment to catch up, and it's still faster than popping into neutral and matching the revs. I used to be skilled at on my old beater tercel though Oh how I miss my $300 POS.
#45 |
Cigar Smoking Man
Last Online: 2:19 AM
Car: 07 Subaru WRX, 09 VW Tiguan.
I used to do it in my Grand Am and Sunfire, since they were the same transmission (Getrag) It was easy to find the sweet spot. Haven't bothered yet with WRX, and I probably never will. They have enough trans issues as it is.
When I first was driving a manual, I actually did the Initial D trick of water in a cup, though this was in 2000 and I was not aware of Initial D until 2003; my driving instructor in high school used it on students to smooth out steering, accelerating and braking. It really works, and makes you conscious of how you are shifting. |
#46 |
Tried it on a old van at work (think one of those big behemoth ups delivery vans), and I was able to do it first time out. I don't really see a point of doing it with any kind of regularity though; only in an emergency. It wears the synchros unnecessarily, and honestly it takes longer. You pop it out of gear, you have to wait for the revs to fall to pop it into gear (well I suppose you could hold it against the next gate and it would pop in when the revs fall far enough, but the synchros wouldn't last a 100 miles like that). Using the clutch, you dip the clutch, swap cogs and bam you can let the clutch take up the difference in revs without any waiting.
I'd never do it in my own car unless the clutch hydraulics gave out preventing me from using it.
#47 |
Master of Disaster
If it has a dog box, I don't use a clutch. If it has synchros, I do.
Conventional cars with synchros and curve-cut gears aren't intended to shifting without the clutch. That said, I *always* heel-toe my downshifts. Steve |
#48 |
#49 |
Never tried and never will on any of my cars.
#50 |
Last Online: July 2nd, 2009
Car: 1994 Eagle Talon, 1992 Galant VR-4
Long ago I replaced the clutch in my Eclipse with a heavy-duty model that had a very upgraded pressure plate. After driving for a bit one day the heavy-duty pressure plate simultaneously snapped my clutch fork in half while blowing up my clutch slave cylinder.
I had no idea how I was going to drive it home and my father came to the rescue, he showed me how to rev-match the gearboxs so that you could shift easily without damaging the synchros (no grinding whatsoever) and we took it home. Every so often I'll practice that technique on a long drive but it's handy to know, especially if you know how to do it well. Oh, and this is my first post, hello everyone.
'92 Mitsubishi Galant VR-4 2.0l 4G63, Daily '94 Eagle Talon TSi AWD 2.3l 4G63, BUILT |
#51 |
I'm unable to heel toe consistently due to some leg injuries I sustained as a child so I've learned to left foot brake and rev-match with clutchless downshifting instead while at the track. As long as you rev-match properly it's perfectly fine on the transmission.
#52 | |
Last Online: 2:00 AM
Car: 1988 Ford Laser Ghia
#53 | ||
Excellent taste in cars. I'd have loved a Galant VR4 had I been able to find one when I picked up my 318. Feel like trading?
#54 |
Last Online: September 6th, 2009
Car: '91 Mazda MX5 NA6CE
Haha, same here with my old MK1 MR2. Came out to the car on my lunch break at work and wondered what the fluid was on the floor, thinking it looked like hydraulic fluid. Turned out it was, I had enough left to shift into first and drive out of the car-park as normal (to get the car home just over a mile away), and then it gave up on me completely as I merged with traffic, typically enough. I'd heard it could be done, so after plenty of crunching and swearing, finally got the hang of it.
#55 |
why would it even try it? The awful screeching noise when I haven't depressed the clutch pedal fully a couple of times (by accident) is enough of an experience.
#56 |
Hedgehog Sandwich
Never really tried it, but I know that without the clutch I would need a hammer to get the gear lever into neutral. Aside from that I really have to rev it to match the revs shifting up and that isn't good for the old engine.
#57 |
Thats because you didn't match revs properly.
#58 |
Last Online: 3:57 AM
Car: '78 MG Midget, '78 Honda CB400t
Rev matching is never bad for an engine. If you do it properly it will easily shift.
![]() "If you think about it breast implants aren't much different than braces. Their main purpose is to improve one's appearance, at least that's how it was in my case." - KaJun "Anyway, I'm off to eat my dick" - Austere |
#59 | ||
To change down, again, come off the throttle, push it out of gear, give it a good solid blip of the throttle(more is better), and slide it into the next gear. If you matched the revs well, it should again pop in with no effort. While I'm not suggesting you go out and drive constantly like this, you should try at least a couple of gear changes ... wont damage anything, but you could learn something new that can be useful. That or rent a car and go at it.
#60 | |
Hedgehog Sandwich
![]() Gearbox is slightly more agricultural than that on a normal car, and it takes a good pull to get it into neutral using the clutch. I might try it tonight, was going to yesterday but chickened out and used the clutch.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can you drive a Manual transmission? | Crazyjeeper | General Automotive | 140 | September 14th, 2008 6:09 AM |
| Automatic or Manual, what do you drive? | ruuman | General Automotive | 111 | January 8th, 2007 3:58 AM |
| Entirely theretical question about Triptronic/Clutchless Manual: | Whappeh | General Automotive | 9 | December 27th, 2006 2:51 PM |
| New driving system allows paraplegics to drive manual-shift | Mischief007 | Automotive News / Spy Shots / Concepts / Rumor Mill | 9 | July 14th, 2006 2:04 PM |
| Do you drive Manual / Standard transmission in the UK? | Operator | General Automotive | 44 | December 5th, 2005 8:15 AM |
