| Register | iSpy | Wiki | All Albums | gXboxLive | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| This is the place to discuss everything related to Top Gear, Fifth Gear, and more! However, to gain full access to these forums, you will need to register. As a registered member, you will be able to:
All this and much more is available to you absolutely free when you register for an account, so sign up today! If you have any problems with the registration process or logging into your account, you can contact us. Already have an account? Login to the upper-right to hide this message and all advertisements on the forums. | |
| Questions & Answers Have a technical question which is automotive related or want to share your mechanical knowledge? This is the right place! |
| | LinkBack | Thread Tools | Search this Thread |
| | #21 |
| Oh I found an exerpt from his book...how lucky (Its a good book I would recommend it, its called Economic Naturalist by Robert Frank) "If all manufacturers had happened to place fuel filler doors on, say, the left side of the car, one consequence would have been long gas lines during peak hours, because drivers in most countries would pull up on the right side of the pump. And in that case, manufacturers would have had a problem worth addressing."
__________________ | |
| | #22 |
| Joined: Oct 15th, 2007 Last Online: 07:45 AM Location: Laramie, Wyoming Age: 20 Posts: 274
Car: 1969 Mustang Coupe - 01 Grand Prix GTP Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() | |
| | #23 | |
| Joined: May 21st, 2004 Last Online: 07:01 AM Location: New York City! Age: 19 Posts: 1,143
Car: 2008 Audi A4 2.0T Rep Power: 20 ![]() | Quote:
| | #24 | |
| Joined: Apr 8th, 2005 Last Online: 07:09 AM Posts: 1,084
Rep Power: 29 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Quote:
If cars only had fillers on one side and petrol stations put the pumps closer together so you could only fit one car between them you would be able to get just as many cars through. | |
| | #25 |
| Joined: Dec 20th, 2004 Last Online: 04:30 AM Location: Bahrain Posts: 1,894
Car: '02 Nissan X-Trail, '06 Honda Civic EXi Rep Power: 52 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Doesn't the different side for fuel fillers occur when cars are made for certain markets but get incorporated for others, especially Japanese cars, most these days guess have it on the same side as the driver, but older cars or cars brought over due to apparent demand, they might not ge the same treatment, just a driving side change. |
| | #26 | |
| Quote:
![]() anyway, with regards to the question, I was always told that European manufacturers mostly have the caps on the right side (ie not the drivers side) and most Japanese ones had theirs on the left side. I was also told this was because Japanese cars were originally RHD. Was I told rubbish? ![]() | ||
| | #27 |
Car: '02 Nissan X-Trail, '06 Honda Civic EXi Rep Power: 52 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | It makes some sense because you can then get out of the car and go to pay/buy stuff from the shops there without having to go between the filler and your car which you usually park close to. It all gets messed up when they change over for other markets. |
| | #28 | ||
| Joined: Feb 1st, 2007 Last Online: 07:33 AM Location: Dallas, Texas USA Age: 31 Posts: 3,009
Car: 87 XJ6, 95 XJR, 90 WD21, 86 CB700SC Rep Power: 52 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Quote:
![]() ![]() ![]() Quote:
Nissans traditionally have their fillers on the right side. Toyota does as well, at least on their trucks. Honda tends to put them whereever. Don't know about Mitsu, don't care. Jeep usually puts them on the left. There are various arguments either way - such as putting it on the off-side makes it obvious that you've left the fuel door open (should you do so) when you check your offside rearview mirror.
__________________ ![]() 1986 Honda Nighthawk 700S (project, light restoration in progress) 1987 Jaguar XJ6 Series III Vanden Plas (modified) 1990 Nissan (WD21) Pathfinder SE 4x4 (little red offroad commuter box) 1995 Jaguar (X300) XJR (modified) My truck can swim the English Channel; what can yours do? It's just another day / Where people cling to light / To drive away the fear / That comes with every night | ||
| | #29 |
Car: '02 Nissan X-Trail, '06 Honda Civic EXi Rep Power: 52 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | All the nissans we have had them on the left, probably cos we got jap spec but with LHD maybe? |
| | #30 | |
| Joined: Apr 24th, 2006 Last Online: Yesterday Location: Berkeley & San Diego, California Age: 21 Posts: 1,448
Car: Invisible boatmobile Rep Power: 59 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Quote:
Same goes for it was on the left. As for why they put the filler caps on different sides: I have no clue. Maybe the universe might rip in half if you don't balance out which side the fuel caps goes on.
__________________ Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life | |
| | #31 |
Car: 87 XJ6, 95 XJR, 90 WD21, 86 CB700SC Rep Power: 52 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | They made Terranos and Hardbody pickups with it on the left???
| | #32 |
| Joined: Mar 21st, 2006 Last Online: Yesterday Location: Southampton Posts: 5,806
Car: Vauxhall Zafira 1.9 TDI Slush box. Rep Power: 50 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Right it has changed over time. Many many years ago petrol pumps faced the road and were serviced by a petrol pump attendant and as the pumps faced the road you could only pull in one way. In the UK that meant that the pump was on your left always, you were not supposed to pull in 'against' the traffic, and meant a 180 deg turn if the petrol station was on the other side of the road. The attendant would ask you how much you wanted and fill you up. But the upshot was that the fuel filler cap was always on the near side of the car. But as I said this was many many years ago, the car that exemplifies this approach and is still around is the old mini. Again, the exhaust was placed away from pedestrians that is on the off side of the car. Now over time and as LHD cars were converted for RHD use and vice versa, and petrol stations went for dual side service and self service all this went out of the window, bit like the indicators and the windscreen wiper stalks which changed too. There was no law for this it was manufacturers trying to be nice to their customers. I am talking about sometime in the early 60s when the small petrol station with pump attendants started to close. |
| | #33 |
Car: 87 XJ6, 95 XJR, 90 WD21, 86 CB700SC Rep Power: 52 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | The closure of small stations didn't happen in the US until the 80s, really. And road-facing pumps usually had an entrance on both sides, so you could pull up to them either way. Dual side service pumps have been around in the US since the 50s, IIRC.
| | #34 |
| Joined: Jun 3rd, 2008 Last Online: 08:04 AM Location: Monaco di Baviera Age: 20 Posts: 963
Car: VW Golf IV 1.6 Rep Power: 19 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Almost every car I have ever driven (well, every car I fuelled up on anyways) had the cap on the right. So I usually go to a right facing pump. But even if, due to all rightside pumps being full, i need to go to a left one, it's no problem. Here in Bavaria at least, the fuel pump hoses can be extended, you just need to pull a bit. It's no problem to stretch around the back of the car if you pulled forward enough, and just fill up the other side. On another note, most gas stations I go to people usually drive through one direction (eg side of a major road, can only be reached when driving in one direction). Even when you're allowed to go through both ways, I get the impression that most people go through in the same direction as the road that leads them there, or if its parallel to the road, the same direction as the closer side of the road. |
| | #35 |
Car: Vauxhall Zafira 1.9 TDI Slush box. Rep Power: 50 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Yes it came over from the States, but I remember them being as I describe. The economic reasons quoted are the reasons that sustain the situation but were not the original reasons. Most cars stayed in the home territorities until the 60s only since then have we had the mix up. |
| | #36 |
| Spectre, that picture is just awesome! ![]()
__________________ Yes, it tells us that you participate in the mass cultural delusion that the sun's apparent position relative to arbitrarily defined constellations at the time of your birth somehow affects your personality. | |
| | #37 |
| Gulf Livery Rules | I don't like the petrol stations where you can enter from any side you want and just stop anywhere you want. On a recent trip to italy i saw 2 accidents that happened just because of that. The drivers came to the exact same pump from opposite sides, 1 had the door on the left, 1 on the right and they crashed head on. Around here, we only have "one way street" petrol pumps. My car has it on the left and as someone mentioned, the single exhaust is on the right. My dad's has dual exhausts and the door on the right, my mum's has the door on the right too, but i've no idea where the exhaust is. :S If this keeps up, we'll end up discovering it's down to the flip of a coin... But yeah, awesome pic that. Your wallet must scream in agony when you do that. ![]() |
| | #38 |
| I like when a car on the instrument cluster shows which side the fuel filler door is on. However, I've noticed of those cars, only like half of them are lit up at night. What bloody good is it to have the graphic on the cluster if it doesn't light up so if the first time you drive a car is at night, you can't see it?
__________________ "- ... But don't dawdle. Get the car into top gear as quickly as is reasonable. Fifth gear, remember, is no good at all." -- Jeremy Clarkson | |
| | #39 | |
| Joined: Oct 5th, 2006 Last Online: November 28th, 2008 Location: Somewhere small and far away Age: 18 Posts: 480
Car: 94 Buick Century - 86 Pontiac Grand Prix Rep Power: 11 ![]() ![]() ![]() | Quote: |
