Yeah, I sure did! It's kind of a (tragically) funny story.
So, on the weekend we moved the Jeep into my dad's shop so I could pull the engine/trans out and really tear things down.
First, we had to pull out my dad's project car so we could move it to our storage garage while I worked on mine.
Went to my place, loaded up the Jeep onto the hauler for the trip to the shop. Ironically, despite all the wheeling it's done, this was the first time it's needed to be winched. :lol:
Back at the shop, we managed to push the ZJ up and over the curb by hand, but the sustained slope was too much for the two of us. Thus, we grabbed my mother's Rubicon, threw it in 4LO and idle-pushed it up the driveway.
In the garage, finally. Pulled the hood for engine access.
This is how far I'd stripped it down in my parking lot, but bad weather all week had kept me from going any further.
Personally, I wanted to just do an engine swap, but I determined that the header's wouldn't fit. Oh, well!
Many linkages were unbolted and wires unplugged, and the engine is almost ready to be yanked.
Pulled the transfer case for ease of removal, now it's ready to be pulled.
Out, finally!
Required.
Got the motor on the engine stand, started removing all the bits and pieces. Everything looked normal, until....
....I pulled the passenger-side head. Gee, that piston looks pretty cracked. Wait, what is
that?
GODDAMNIT WHY THE FUCK IS THERE A TORX BIT IN MY COMBUSTION CHAMBER. YOU SON OF A BITCH.
So, at this point it became suddenly apparent what had happened, but there's more to the story. Way back last year when I first bought the Jeep, the very first thing I ever did with it was clean the IAC valve on the back of the throttle body as the idle was a bit odd. The ISC is in a very awkward position with little clearance, so I was forced to use a removable screwdriver bit in a ratchet to get at the two Torx bolts holding it to the back of the TB. While I was reassembling it, I dropped the bit down the back of the engine. I searched for that fucking thing for HOURS. Magnets, flashlight, I couldn't find it for the life of me. Every time I went under the hood to work on something, I looked for that damned bit. eventually I was forced to assume it had fallen out of the engine bay while I was driving.
Flash forward to a few weeks ago. After lots of driving and many bumpy offroading trips, the Torx bit must have somehow migrated forward to the front passenger side injector pair and was in a position near the injector hole for that cylinder. Keep in mind that the ECU wiring, fuel rail, and a vacuum line cluster all run down that area. As soon as I pulled the rail with injectors attached, the bit must have been in the perfect position and jumped in the hole. Here's a picture showing in red where the Torx bolt I was working on was when I lost it, and in green the hole it went in over a year later.
Also note that the hole has a raised lip around it to help protect against exactly this kind of thing. I afterward attempted to find a position it could have rested in on the intake manifold to drop in, and after a number of trials I was completely unable to make the bit fall in the hole. It barely fits in end-on. The chances of the series of events conspiring to have this happen was infinitesimally small... and yet there's a damn Torx bit in my piston. :lol:
So, yeah, that's the story more or less. In a small stroke of luck the cylinder wall looks to actually be in quite good shape, so a rebore may not even be necessary. The head was not so lucky, as the bit took a small chunk out of a non-sealing surface; not critical, but I'll likely just grab a junkyard head for $40 and rebuild it along with the other one. The transmission also seems to have degraded badly in the months since I swapped transfer cases, as it gushed some pretty badly burnt ATF when I pulled the TC, indicating that it's blown an internal seal and something was badly overheating itself. The culprit may have been a clogged checkvalve by the trans cooler, which would have kept the ATF from circulating and cooling properly. Thus, I will be having the trans rebuilt and likely upgraded to 49RH spec.
Bonus image: The piston needed to be bashed out with a hammer to unseize thing so I can pull the rest of the internals on Sunday. Hulk smash!
