Forum Suggestions / Issues
mgkdk
Aced mod training!
Denmark
VW UP! Renault Clio
Found a tiny little thing while looking in the entertainment forum, there is a line missing between the flame and the text in the LFS forum.
wingnutsc
Los Angeles, CA, USA
'06 Honda Element
is there a way so as to only show unviewed posts since the last time i visited, not every unviewed post from previous sessions?
Viper007Bond
Chicken Nugget Connoisseur
Portland, Oregon
No. You'll need to just start getting used to using the "Mark Forums Read" feature which will clear that list out. It can be found in the quick links at the top or at the bottom of the forum home.
Viper007Bond
Portland, Oregon
Woah, indeed it does.
Have you tried hitting control + 0 (reset font size to 100%)?
STrRedWolf
Severn, MD
Looking for one.
That is at 100% font size in Firefox 2.0. Screen DPI's not what is assumed to be in Windows -- I'm running at a higher dots-per-inch setting (about 135 dpi). Windows usually is around 96 dpi.
Turns out vBulliten uses points instead of pixel heights for fonts. :(
Viper007Bond
Portland, Oregon
No it doesn't. Look at the CSS file. There's only one or two font size declarations that are in pt form.
And it's not my fault if you're running a higher DPI. ;) Best I can suggest is you press control and minus a few times to shrink the fonts.
Viper007Bond
Portland, Oregon
STrRedWolf
Severn, MD
Looking for one.
I did, as well as slap it through Firefox's DOM Inspector. I ended up adjusting the CSS styles for the P, TD, TH, LI, STRONG, and TEXTAREA tags as well as the "tcat," "alt2," "bginput," and "bigusername" CSS style classes.
Besides, the Font zoom options affects the browser and doesn't carry over to new tabs. If I pull up, say, Slashdot, I don't have to do any major font adjustments. Spacing adjustments, though....
SV
Adelaide, Australia
'03 BA Ford Falcon XR6
Not a big problem i guess but i just noticed that on the vB code page one of the things is in the wrong place.
It says YouTube Video with Custom title twice, once for the google code.
nicksoup
ClubRSX
Acura RSX Type S
Suggestion
Suggestion
Custom User titles?? Or is that reserved for moderators?
XYZviper
Lithuania
TOYOTA Yaris
My avatar works, but my sig doesn't. :( It is corect size and everything, but it doesint show. :(
Viper007Bond
Portland, Oregon
You have to enter [sigpic] or something like that in your sig where you want it to show up.
I'm going to turn off that feature though. Having people use ImageShack and the likes is just easier.
