Harley recalls 250,000 bikes for brake problems.
Blind_Io
"Be The Match" Registered
Utah
See signature
http://abcnews.go.com/Business/wireStory/harley-recalls-175k-bikes-brakes-fail-52900102
Under pressure from U.S. safety regulators, Harley-Davidson is recalling over 250,000 motorcycles worldwide because the brakes might fail.
Documents posted Wednesday by the U.S. National Highway Traffic Safety Administration say the recall covers more than 30 models from the 2008 through 2011 model years. Harley says deposits can form on brake parts if the fluid isn't changed every two years as specified in the owner's manual. That can cause a valve in the antilock brake control unit to stick.
The U.S. agency began investigating problems in July of 2016 after getting 43 complaints including three reports of crashes and two injuries.
Documents show Harley wanted to do a field service campaign instead of a recall, but the government refused.
The company says it cooperated with NHTSA and began a thorough evaluation of the issue. "Complex, ongoing discussions regarding what was ultimately identified as a maintenance issue continued with the agency through January 2018," Harley-Davidson said in a printed statement.
The recall covers nearly 175,000 motorcycles in the U.S.
Dealers will flush and replace brake fluid starting on Feb. 12.
This is not the first time that HD has had problems with their brakes, when they shipped their brand new entry-level bikes out for testing they experienced brake failure in 60-0 tests due to boiling brake fluid. HD has had to recall bikes in the past for braking issues, a similar complaint to this one was originally brought up in the summer of 2016.
