yuchungman
Here's my spec:
Intel Core i5-750(stock clock)
ASUS P7P55D
4Gb RAM
GTX 260+
Windows 7 Ultimate 32 bit
I used to have an Edimax EW-7711uan USB reciever. It worked fine in two XP systems I used to won. When I try to install it with the the reciever plugged in, the prograss bar stuck and didn't move. I plugged out the reciever and the installation was completed. But after that, the software that runs the reciever cannot detect the reciever when I plug it in, and windows can't find a proper driver to run the reciever. The real headache is that when the reciever is plugged in, I can't either shut down my computer or boot it up(after the windows loading screen, everything went black). The software that runs the reciever is installed, but I can never get into the window of the program.
I thought it was the manufacture's problem of making a bad driver for Windows 7.. So I bought a Tenda W311U reciever and the same problem occured: Can't install while the reciever is attached and the software can't detect that damn reciever. But this time Windows says they've found a driver that can run the reciever as soon as I pulled out the new reciever. But I still can't make it to work.
I've put a lot of money into the new system, and it is simply a heartache to see it doesn't work, please help!
ASUS P7P55D
4Gb RAM
GTX 260+
