Top 25 Members' Cars/Motorcycles of Final Gear 2012
jsausley
Burlington, NC, United States
'16 Audi S5, '14 CC R-Line, '12 Ariel Atom 3
Ooo, this sounds fun.
What sort of rules? One entry per person? Does it need a thread in Post Your Car or just a good picture and a proof picture?
Seattle
As always it will require a thread in PYC with a proof pic.
Jupix
I was rather bored the other day so I wrote a webscript.
http://jupix.info/fgcar2012/
The back end is about 90% done. Oh and I did change the point system to utilize whole integers and no decimals.
I would just need the help of someone who knows javascript... It is a far better solution to check the "ballot" before the user clicks submit, rather than only doing it in PHP when the form is processed. So, I would need javascript to check that there are under 10 (or 5) checkbox ticks in each category, and that those cars are only ticked in one category. If anyone could write it, that would be awesome.
Seattle
Thats fantastic. To prevent cheating I was thinking about having members PM me for a special per user code then for them to use that to vote.
Viper007Bond
Chicken Nugget Connoisseur
Portland, Oregon
Give the <form> an ID of "votingform", i.e. <form id="votingform" ... > and then add this to your <head>:
HTML:
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.7.1/jquery.min.js"></script>
<script type="text/javascript">
	jQuery(document).ready(function($){
		// Bind some code to the form submit event
		$("#votingform").submit(function(event) {
			// Select all checked checkboxes and count them
			var checked_count = $("#votingform input:checked").length;
			// If there's too many checked...
			if ( checked_count > 5 ) {
				// Tell the user
				alert( "You voted for " + checked_count + " items which is more than the 5 item maximum!" );
				// And prevent the action from occurring (the form submission)
				event.preventDefault();
</script>
jQuery makes Javascript easy. :)
Note that of course you still need to enforce this on the PHP side too because someone could disable Javascript.
EDIT: Oh, I just noticed that the form is more complicated than I thought (people vote for their 1st, 2nd, and 3rd choices). You'll need to modify my code but it's easy enough. http://api.jquery.com/category/selectors/
Also I would randomly sort the cars on each page load so that there's no bias.
If you need any help with this, let me know. I literally do this (PHP development) for a living. :)
Jupix
That's a real nice idea if you can be arsed to handle the pm thing. I coded the webapp under the assumption you'd had enough of the administrative overhead.
(snip)
Thanks for your interest and effort so far! Unfortunately making the necessary modifications would require learning the js syntax and aforementioned library from scratch, which I don't have time for (or interest tbh) at present. The webapps I've written with php so far have utilized very little js and the few scripts I've used have been stock clips. If you could finish the script that would be awesome. I'm guessing to you it would be a breeze.
Seattle
It's not a big issue for me.
Viper007Bond
Portland, Oregon
If you know PHP, HTML, and CSS, then picking up jQuery wouldn't be that hard but whatever. :?
HTML:
			var max_votes_per_type = 5;
			// Each grouping of checkboxes, identified by "name" value
			var voting_types = new Array(
				"v1_options",
				"v2_options",
				"v4_options" // No trailing comma! IE is a piece of shit
			// Loop through each group
			var array_len = voting_types.length;
			for ( var i = 0; i < array_len; i++ ) {
				var checked_count = $("#votingform input[name='" + voting_types[i] + "[]']:checked").length;
				if ( checked_count > max_votes_per_type ) {
					// Tell the user
					alert( "You voted for " + checked_count + " items in a single column which is more than the " + max_votes_per_type + " item maximum!" );
					// No need to check the other columns
					return;
</script>
Der Stig
is Der Slut
Misery Knob
Too many and yet not enough
ALL HAIL TO THE GLORIOUS LEADER'S PUNCTUALLY ARRIVING FOUR-WHEELED SNAKE.
Also, Pry's Beetle, avanti's GSX-R 750, Blind's VFR and Bub's DRZ :p
Seattle
I will keep the rules as it was last time. 50 post minimum with six months of membership required to have your car nominated. Anyone who meets these requirements may nominate an eligible vehicle.
If there are over 25 nominations there wil be two votes. The first will be for all cars nominated with the top 25 being included in the final vote.
Seattle
Once nominations are done, I'm thinking of having a shorter voting period than last time. Perhaps two weeks?
Jupix
I think we can draw some conclusions from the nomination activity; 2 weeks is plenty, and pretty much an absolute maximum. We might want to consider even going as short as 1 week.
