Windows problem or hdd problem
Ice_warmer
eastern ieurope
Every single time i start up windows a partition needs to be checked (just before the list of users show), first time it appeard i let it do it's thing and at the next restart it does the same thing, even after i've reinstalled a fresh copy of windows, anyone know any info on this ?
Thanks
Z102
Valencia, Spain
'07 Ford Fiesta 1.6 Sport
Are you sure Windows is shutting down properly? Sometimes it may BSOD shortly before the PC restarts and that may cause the disks to be flagged for a check on the next startup.
MadCow809
Thanks
time to move on to NTFS
MadCow809
i had the same problem with my old laptop a few years ago. i changed it to ntfs and the scandisk problem is gone.
IMO you will have to format in the future anyway, so might as well as clean up ur hdd and re-format to ntfs.
you other solution will be having to run a full system scandisk in order to get that annoying bootup scandisk procedure to go away.
Top Geek
Canadaland :)
1995 Nissan 240SX
If you're running 9X, it's time to get out of the dark ages. It's way past it's support period and downright dangerous to be using.
Otherwise, you can convert your partition to NTFS without damaging it.
the Interceptor
I LUV MY PRIUS!!!
ze Vaterland
VW Diesel of Death
As a temporary solution to the scandisc problem (not really a "solution", more like a workaround), you can switch the "perform scandisc at startup after faulty shutdown" off somewhere deep within windows (it's a valid system-internal option though). If you are interested, I can look it up for you.
Still, I have to stress that this is no solution for the actual problem, which probably should be adressed in the above posted ways.
Ice_warmer
eastern ieurope
It's xp with sp2
in XP :
1.Close all programs
2.Start-> Run-> cmd
3.when in ms-dos, type :
4.convert C: /FS:NTFS
5.Done
It really is that simple ? Do i have to worry about data loss or something like that ?
I'm really not to good at computers.
I've heard that windows hdd scan is pretty recomended (not because it says just before it starts that is recommended to let it do it's thing, someone told me :p) if it has some errors, it can help ... at least that what he said
73GMCSprint
Southern UT, USA
It's xp with sp2
Yep. It's really that simple.
Any time you're dealing with a hard drive you should worry about data loss. Really, you should be worrying about potential data loss whenever you use the computer. Always keep your important files backed up, and I'd do a backup of your essential files before you convert. You shouldn't have any problems, but you never know.
Hatmouse
La Jolla, California
'03 Civic Si
It's xp with sp2
Formatting a drive partition removes all data on that partition. Make sure you have all the backed up!
73GMCSprint
Southern UT, USA
Converting is NOT formatting. You SHOULDN'T lose data when you convert file systems. I'd still back things up just in case.
evan_a
Brisbane, Australia
Another thought... Make sure there is enough room on the disk (like at least 1.5GB), and maybe defrag it before you start. You could encounter issues if the disk is full, and the defrag will make it quicker.
