| Register | iSpy | Wiki | All Albums | gXboxLive | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| This is the place to discuss everything related to Top Gear, Fifth Gear, and more! However, to gain full access to these forums, you will need to register. As a registered member, you will be able to:
All this and much more is available to you absolutely free when you register for an account, so sign up today! If you have any problems with the registration process or logging into your account, you can contact us. Already have an account? Login to the upper-right to hide this message and all advertisements on the forums. | |
| TG Specific Episode Discussions Talk about specific Top Gear episodes. |
| | LinkBack (2) | Thread Tools | Search this Thread |
| | #201 |
| Joined: Feb 20th, 2006 Last Online: October 25th, 2008 Posts: 6
Rep Power: 0 ![]() | Yeah, I guess that's it.
__________________ http://davidnaylor.org/blog/ |
| | #202 |
| Joined: Aug 25th, 2006 Last Online: Yesterday Location: Sydney, Astraya Age: 20 Posts: 1,107
Rep Power: 12 ![]() ![]() | I think the biggest factor in the Veyron not breaking the lap record is the Stigs inhibition to take someone else Million Dollar car to the limit. |
| | #203 |
| Joined: Nov 21st, 2006 Last Online: Yesterday Location: Lil Osaka Posts: 2,159
Car: Legacy GT Spec B '07 Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Much of the Veryon's power that will push it from 150 to 250 mph is essentially useless on the TG test track since its too short and too tight in the corners, thus putting the much lighter CCX at a distinct advantage when it pitches around corners. I think the Keonigsegg can brake relatively later around corners because of this and the Veyron can't really go that much faster in the straights because it'll have to start braking and slowing down earlier. So effectively its usable power on a small track isnt that much greater than the CCX. Ed |
| | #204 |
Rep Power: 0 ![]() | I was about to say that since the Veyron does accelerate faster (due to 4WD), it should in theory be faster round the track, but then I realized that the 4WD doesn't do much when you're already moving properly.
| | #205 |
Rep Power: 12 ![]() ![]() | I can't remember where I heard this, but I think Rear-Wheel-Drive cars are faster than All-Wheel-Drive cars on a dry track. Probably something to do with controlled over-steer. Will this hurt the Bugatti? |
| | #206 |
Rep Power: 0 ![]() | AnGuRuSO, it could be that. It could also be that they generally are lighter and loose less power when only driving two wheels. But those are really only valid if you're comparing cars that are otherwise identical.
| | #207 |
| Joined: May 23rd, 2006 Last Online: October 25th, 2007 Location: Toronto Ontario Posts: 28
Rep Power: 0 ![]() | RWD is faster around corners because the fronts are free to rotate at different revolutions. AWD cars force all wheels to rotate at the same speed, unless you can split the torque with a diff. But the AWD 16:4 would still be faster to 60 on dry or wet. Less wheel spin at launch and the Bugatti probably has bigger tires front and rear. Still, Nick Mason lent TP his F60 for a hot lap, and those are probably worth close to the Veyron's price tag by now.
__________________ Let me tell ya what Melba Toast is packin'. We got 411 positrack out back, 750 double pumper, Edelbroc intakes, Ford over-30, 11-to-1 pop-up pistons, Turbo-jet 390 horsepower. We're talkin' some fuckin' muscle. |
| | #208 |
| Joined: Aug 29th, 2005 Last Online: November 4th, 2007 Location: Denmark Posts: 12
Rep Power: 0 ![]() | The Veyron bit gave me goosebumps... ![]()
__________________ - Flying is simple. You just throw yourself at the ground and miss |
| | #209 |
| Joined: Sep 27th, 2005 Last Online: Yesterday Posts: 976
Car: Vauxhall Corsa SXi 1.2 Oh fuck yeah! Rep Power: 14 ![]() ![]() | RWD is faster around corners because the fronts are free to rotate at different revolutions I thought it was because the torque going through the rear wheels generated more slip (both perpendicular and parallel to forward motion), thus helping the car turn.
__________________ |
| | #210 |
| AWD's tremendous grip simply causes understeer which slows the car down around a corner just like a FWD car....thus making RWD faster. Thats my understanding of it ![]() Last edited by 80ssportlover; February 9th, 2007 at 10:59 PM.. | |
| | #211 |
| Joined: Jun 18th, 2005 Last Online: Yesterday Location: Australia Age: 21 Posts: 2,230
Car: 2008 MY09 Subaru Impreza RX Rep Power: 24 ![]() ![]() ![]() ![]() ![]() ![]() ![]() | I just watched this episode yesterday and the James May/Veyron segment was a really great story. Well done to James for hitting 253mph!
__________________ ![]() |
| | #212 |
| FG's Highest Paid Male Whore Joined: May 26th, 2005 Last Online: Yesterday Location: Vancouver, Canada Posts: 8,322
Car: IS250 RWD Rep Power: 86 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | I especially enjoyed his comments after he was done his run... he seemed genuinely speechless which isn't usually the case. |
| | #213 |
| I was a bit surprised about James being speechless after the Veyron 400kmh run, since he wrote in the TG magazine this summer that it does not feel particulary fast... but anyways, James's part was great. The rest was really good too, and I liked that a star in a reasonably priced car was somebody who I know since I am not british.. I was looking forward to the new TT very much, but I was kind of confused, so is it any good or not?
__________________ "pooooooweeeerr" well, not in my car, that's for sure | |
| | #214 | |
Car: 2008 MY09 Subaru Impreza RX Rep Power: 24 ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Quote:
__________________ ![]() | |
| | #215 |
| | #216 |
| Joined: Jan 28th, 2007 Last Online: January 1st, 2008 Posts: 29
Rep Power: 0 ![]() | top gear utterly destroyed some guys old jag race car (d-type?) a while ago, guy was pissed not sure what came of it. |
| | #217 |
| Joined: Feb 12th, 2007 Last Online: March 16th, 2007 Location: vienna/VA/USA Posts: 3
Rep Power: 0 ![]() | hey ... does anyone have a link for the train crash .. and wat is this train crash ... who crashed and with what car??.... i thought the comment on the TT was not totally fair ... the TT looks really great in person and the Alfa does not give a feeling of being a chick magnet ... it wud probably suit a guy of 40 who is still not married and is out tos core on a lady of 47 ... the Veyron is a masterpiece.. was kinda sad bugatti dint let it go arnd the track... Stig wud have loved it .. |
| | #218 |
| Joined: Feb 14th, 2007 Last Online: February 19th, 2007 Location: Shawnee/KS/US Posts: 4
Car: BMW e36 Rep Power: 0 ![]() | I agree the Veyron bit was a thrill to watch. Good choice having the Pretentious Sunday driving James May to do the test drive. The Gallery was quite humorous and a bit different from the usual stuff. You can only smash and blow so many things up. The Hugh Grant plug was a new low point. If that was the price to get him on then they should have passed on him. I disagree about the comments on the previous show. I really enjoyed the Jamie Oliver part. |
| | #219 |
| Loves Vicki... Joined: Mar 26th, 2005 Last Online: Yesterday Location: New York Posts: 798
Rep Power: 15 ![]() | When they were golfing, Jeremy called Richard's RX8 "chincey." Can anyone tell this American what that means? :-\
__________________ no pictures cluttering the board here |
| | #220 |
| Pronounced "Chintzey" although since its a slang term you can spell it however you like really. Argh explaining slang is so hard.....ummmm sort of flash for the wrong reasons. They styled it for the sake of styling it sort of thing..... | |
LinkBacks (?)
LinkBack to this Thread: http://forums.finalgear.com/top-gear-episode-discussions/09x02-february-4th-2007-a-16577/ | ||||
| Posted By | For | Type | Date | |
| David Naylor: Blog: Top Gear's <q>The Stig</q> without a helmet? | This thread | Refback | April 3rd, 2008 11:13 AM | |
| David Naylor: Blog: February 2007 | This thread | Refback | February 19th, 2008 11:18 AM | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| [09x02] February 4th, 2007 | SL65 | TG Pre-Episode Discussions | 82 | February 4th, 2007 08:12 PM |
| [09x02] April 17th, 2006 | Viper007Bond | FG Specific Episode Discussions | 99 | May 19th, 2006 05:20 PM |
| FG - [09x02] - April 17th, 2006 | Viper007Bond | FG What's That Song? | 1 | April 25th, 2006 01:11 PM |
| [09x02] April 17th, 2006 | SL65 | FG Pre-Episode Discussions | 14 | April 18th, 2006 02:41 AM |
| February Ex 2 | Raheel | Photoshopping | 17 | February 26th, 2006 05:40 PM |
