| Register | iSpy | Wiki | gXboxLive | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| Top Gear Jeremy Clarkson, Richard Hammond, and James May host the best automotive television show in the world. |
LinkBack | Thread Tools | Search this Thread |
#21 |
Last Online: November 29th, 2009
Yeah but the thing is all those electrical devices use such a little amount power (relatively) it wont effect fuel consumption.
I mean, even a very high end stereo would only use around 1000W, or 1KW. So when you consider most engines produce 100+kws, its not very much. I do know that you dont always use maximum power from the engine, and while coasting you probably only use 20-30kw or so depending. But a standard radio at normal level probably uses 50-100w which is next to nothing. More fuel can be saved in driving style. |
#22 |
Car: MINI
well yeah, fuel consumption is mainly up to the driver, and a normal radio isn´t going to use a lot of power. But these small things do add up, and as you already pointed out, you´re not always around your car´s maximum power output, in fact, when you´re trying to save fuel and driving accordingly you will be in an area where 1KW actually does make a difference, especially considering the energy loss through the alternator just producing lots of heat at high output...
#23 | |
if u think about it. with no appliances on the engine must run the car so it can move, all the pumps and ancillaries so it can continue to function, it must recharge the battery as it discharges to fire the spark plugs. now u could assume thats a balanced cycle, i.e. the net energy is zero. now toss in a few electronic gubins and that unbalances the whole thing, there are now some components requiring energy and that energy cant be simply taken by reducing the energy given to all other parts, it must be generated in addition. i.e to balance the cycle, we need more power to cover the power consumed by the new additions. the only way that can happen is by burning a tiny bit more fuel. we are talking very very small amounts here though, so small you may not even notice, but it is happening. |
#24 |
I LUV MY PRIUS!!!
... and don't forget that the average alternator only has an efficiency of 50-62%. So for getting 1000 Watts of electrical power out, which shouldn't be much of a problem with stereo, lights, seat heater, rear window heater and so on, you actually need to put in 1613-2000 mechanical Watts.
"My next attempt to make [the Nikon 14-24mm] look bad saw me shooting at ISO400 with the Canon 5D wide open at a distance of less than three feet. I know it's wrong, but this lens just brings out my inner Ken Rockwell." - 16-9.net Got a question regarding Hi-Fi of any kind? Then check my general audio thread. |
#25 | |
Ambitious but rubbish!
Last Online: January 25th, 2010
Car: 1998 Subaru Legacy 2.5L
![]() I've heard that using cruise control can reduce fuel consumption. That is, on the motorway/freeway. Something to do with the throttle linkage. Can anyone confirm this? Obviously driving around town when you can be confronted with hills - cruise control is a bad idea as in order to keep the speed-up - it applies large amounts of throttle, often downchanging gear and revving quite hard. Harder than the you would if you were controlling the throttle. Depending on temperature, I follow some Aussie guidelines and have the windows down below about 80km/h. Over that and the windows are up and the air-con is used instead. What do some of you do? |
#26 |
Best opening skit for a tv show ever!
#27 | ||
Moderator
Last Online: November 11th, 2009
Car: 2006 MY07 Astra SRi Turbo
I can't say I ever drive with fuel economy in mind - I just drive sensibly, with an occasional burst of enthusiasm.
www.sniffpetrol.com |
#28 |
I LUV MY PRIUS!!!
I've made the experience that the cruise control always uses more fuel, even when coasting on the Autobahn behind a truck. The way I understand things, cruise control uses more fuel because it does everything to maintain the speed you set. When you're using your foot however, you'd speed up a little when going downhill and slow down a tad when you go up. So in the long run, you'll drive more economically.
#29 | |
Last Online: January 4th, 2010
_______________ Powerrrrr !!!
#30 | |
Last Online: January 10th, 2010
Throttle linkage malarkey, I don't know. If it is an issue at all, it's becoming irrelevant due to the advent of drive-by-wire engines. |
#31 |
Ive noticed too that no matter how 'smart' your CC is, you'll always use more fuel.
Doesn't matter if it's hilly or whatever, your own foot is always easier on the pedal and therefore easier on the mpg |
#32 |
I've done 800 km on a 62 litre tank using techniques like this in my car, and that's marginally more fuel efficient than my friend's Toyota Corolla.
![]() One could always use one of these. |
#33 |
Mrs. D-Fence
A 100W lightbulb uses 0.1 kW, which is 0.13 horsepower. If you're using around 30-40 horsepower to cruise along nicely, that's 4% extra. Right now, i'm using 7.2 l / 100 km and without the lights, i'd be doing 6.9. That comes down to 37 cents per 100 kms or at my mileag, that's 92 euro a year. Just from running 1 100W light 24/7 cause of the law. Suddenly, the audi LED DRLs aren't just stylish, but save you around 80 euro a year too.
But that's peanuts.. |
#34 | |
I LUV MY PRIUS!!!
#35 |
Mrs. D-Fence
Oh yeah, whoops.
![]() So... that comes down to 9 euros a year. At this rate, I'll go broke! |
#36 |
Last Online: February 7th, 2010
Car: 2008 VW Golf gti mk5
He has an M3 e92?
#37 |
For any who want to see the effects of the electrical components for themselves, go out to your car, start it up, and turn on as many electrical accessories as you please, then open the hood and unplug your alternator, if you can easily. My bet is that you'll hear your engine speed up. Plug it in, and you'll hear the load on it.
Driving through New Mexico with a nearly dead battery at night is no fun, let me tell ya. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Saving e-mails and folders in Outlook Express 6? | avanti | Technology | 11 | February 25th, 2008 2:20 PM |
| saving you tube clips on HD? | avanti | Technology | 10 | May 20th, 2007 7:28 PM |
| Frankfurt Motor Show: BMW reveals energy-saving measures | Overheat | Automotive News / Spy Shots / Concepts / Rumor Mill | 0 | September 14th, 2005 6:34 PM |
| saving my mailbox | Thrasher | The Site Itself | 7 | July 20th, 2005 4:55 PM |
| has this forum daylight-saving time? | viilaaja@pt cruiser | The Forums | 30 | April 9th, 2005 12:05 AM |
