+ Reply to Thread
Page 2 of 4
FirstFirst 1 2 3 4 LastLast
Results 21 to 40 of 62
Thread: Why didn't the Robin seperate with Fuel Tank?
  1. #21
    Lorenzen is idling in neutral
    Feb 22nd, 2007
    Quote Originally Posted by Spectre View Post
    They *were* using British technology to build the thing. The bolt that failed, or some component of the detonation system, probably said LUCAS on it. If they'd been using American tech, the explosive bolt would have worked, since *we* figured those out back in the 60s.
    WE? Americans ? You mean, Wernherr von Braun and it's staff of German Engineers.
    Americans couldn't even get a Jet engine working.
    Please, You Americans twist the History to your end enough already, stay on course with those things you won't make a complete ass out of you.
    thanks.
  2. #22
    Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre has a jaaaaaag worthy rep Spectre's Avatar
    Feb 1st, 2007
    Um, the explosive bolt issue I refer to is what we figured out after the Apollo pad fire when the explosive bolts didn't. We figured those out rather quickly at that point.
    You just want to avoid the fact that it was a Norwegian (Ægidius Elling, 1903) who built the first self-sustaining gas turbine. Sure, a Brit filed the patent (John Barber, 1791), but it took someone else to actually make it work.
    *We* twist history? Bahahahahaahah.... You Brits have no ground on which to stand there - or should I mention the "schools" you ran in Ireland? Or India? Or anywhere else in your empire? I've got some Empire history textbooks from that era and the creative editing that you guys did is absolutely hilarious.
    That Concorde thing worked out real well, too, neh? Is that why Britain's aviation industry has dominion over the skies today? Oh, wait.....
    Should I also point out your standard infantry rifle (designed and built in Britain) is a huge pile of s*** that not even Heckler and Koch can fix?
    Enough is enough.
    We are not here to subsidize your clueless business plans or reward your failures.
    1986 Honda Nighthawk 700S (project, light restoration in progress)
    1987 Jaguar XJ6 Series III Vanden Plas (modified)
    1990 Nissan (WD21) Pathfinder SE 4x4 (little red offroad commuter box)
    1995 Jaguar (X300) XJR
    1998 Honda Pacific Coast PC800 (two-wheeled pickup truck/utility bike)
  3. #23
    Donington has a jaaaaaag worthy rep Donington has a jaaaaaag worthy rep Donington has a jaaaaaag worthy rep Donington has a jaaaaaag worthy rep Donington has a jaaaaaag worthy rep Donington has a jaaaaaag worthy rep Donington has a jaaaaaag worthy rep Donington has a jaaaaaag worthy rep Donington has a jaaaaaag worthy rep Donington has a jaaaaaag worthy rep Donington has a jaaaaaag worthy rep Donington's Avatar
    Jan 26th, 2007
    Royston Vasey, Englandshire
    Did we hurt his feelings? ooooh!
  4. #24
    otispunkmeyer has shifted into second gear otispunkmeyer has shifted into second gear otispunkmeyer has shifted into second gear otispunkmeyer has shifted into second gear otispunkmeyer has shifted into second gear otispunkmeyer has shifted into second gear otispunkmeyer has shifted into second gear otispunkmeyer has shifted into second gear otispunkmeyer has shifted into second gear otispunkmeyer has shifted into second gear otispunkmeyer has shifted into second gear otispunkmeyer's Avatar
    May 15th, 2006
    Loughborough UK
    This would also be why Britain doesn't have a manned space program and never will - nobody in their right mind is willing to get in a spacecraft that has components that say "Made in UK by LUCAS" in it.
    I'd really like to thank the Top Gear team for proving that while the Brits may understand cars, they're complete rubbish for engineering anything else. (/backslam for 9x03]
    you forget that one of lucas's parts features was "explodes"
    heh dream on bud, the british have invented alot of good shit, without some of our inventions you wouldnt even have an army... jet engines and tanks come to mind, hehe you wouldnt even be typing on the net right now if it wasnt for a british man.
    without the german and russian scientists you brought over after WW2 you wouldnt even have a space program as advanced as yours is today so stick that one in a pipe and get smoking (/right back at ya!)
    also, the reason you guys bust the sound barrier......... oh british again! there is video evidence of the fully moving tail plane idea in action on an old WW2 plane. at the time the US were also trying to break the barrier too, so it was decided that the bristish and americans would swap and compare notes, share knowledge. the british governemnt being what it is, the funding was pulled and the project shut down, handily we had shared our info to the US... in return you went and broke the sound barrier. infact the Bell X1 was remarkebly similar to the craft sitting in the british hanger at the time, conveniently it was completely dismantled and only a few B&W photos remain.
    now im not a conspiracy theorist, though they are jolly good, but i wouldnt put it past the US government if they had paid the british gov to pull the plug after the project leaders divluged their information
  5. #25
    Jan 26th, 2007
    We invented..erm, Jaguars?
    Sorry, Jagwaaaaars
  6. #26
    finalgearfan is idling in neutral finalgearfan's Avatar
    Mar 31st, 2005
    I think the launch was spectacular. And that Robin is the luckiest old Robin around!
  7. #27
    May 15th, 2006
    Loughborough UK
    FYI, the Columbia disaster was caused by econazis.
    First of all, the insulation that hit the wing of Columbia isn't a soft sponge. It's a hard coating, and chunks of it came off. I have a sample of the material in a case (from a much happier time, long before Columbia exploded). It's much like a *very* stale biscuit or a chunk of chalk from the Dover cliffs.
    Second, this isn't the original coating that was on the fuel tanks when the thing was designed. The original coating was made using various enviro-unfriendly processes, which included the use of a CFC much like Freon (R-12) as a component. Unfortunately, NASA decided to change to an "environmentally friendly" coating, which, as it turns out, has much less structural integrity. And quite often flakes off on launch. Ooops.
    May I remind you that the only significant British space effort in the last 10 years did a faceplant on Mars and failed because nobody over there figured that an object shaped like a coin might land wrong side up and need to flip itself over, so they didn't give it enough power to be able to do so?
    touche, nice use of language
    yeah that stuff on the fuel tank is no soft sponge at all, and it wouldnt matter if it was considering the speed the shuttle was doing when it came off. the shuttle is a rather fragile bird....but that makes it all the more amazing.
  8. #28
    Disco Inferno KaJuN has a jaaaaaag worthy rep KaJuN has a jaaaaaag worthy rep KaJuN has a jaaaaaag worthy rep KaJuN has a jaaaaaag worthy rep KaJuN has a jaaaaaag worthy rep KaJuN has a jaaaaaag worthy rep KaJuN has a jaaaaaag worthy rep KaJuN has a jaaaaaag worthy rep KaJuN has a jaaaaaag worthy rep KaJuN has a jaaaaaag worthy rep KaJuN has a jaaaaaag worthy rep KaJuN's Avatar
    Jul 31st, 2006
    American in Okinawa
    Actually, NASA has been using explosive bolts throughout it's history of manned space flights. It was a malfunctioning bolt (at least I choose to believe) that led to the sinking of Gus Grissom's capsule. The Apollo 1 accident was caused by a combination of poor hatch design and the pure oxygen environment inside the capsule.
    I'm not at all surprised that Top Gear's shuttle failed. In real space programs, problems are worked out on models and computer simulations. TG's approach of build it, then lauch it and see what happens wasn't very favorable for success.
    D-Fence: Kajun is just outside caressing his Discovery....touching it gently, you know......it is such a dirty bitch.....but he seems to love dirty girls in high heels who are taller then him and have "quite a few pounds" on their hips ^^
    This post was accidentally unearthed from a shallow grave by construction workers.
  9. #29
    May 15th, 2006
    Loughborough UK
    yeah the SA-80 sux cox for sure, made from crummt plastics, but please remember it was a english man that gave the world the rifle in the first place.
  10. #30
    Feb 22nd, 2007
    how nice of you to think I'm british
  11. #31
    Jan 26th, 2007
    I wasn't being entirely serious aobut the sponge, you know...oh hell, what's the use of trying to explain...
  12. #32
    Feb 1st, 2007
    Quote Originally Posted by otispunkmeyer View Post
    Experts disagree on that. It's kind of like the gun itself - nobody's really sure who invented it.
    Enough is enough.
  13. #33
    Feb 1st, 2007
    See, that's just it. The only Lucas parts that explode are the ones that weren't intended to.
    Likewise, if Lucas made a vacuum, it would be the only product they made that didn't suck.
    There wouldn't be a net at all for that Brit to invent a Web for if we Americans hadn't invented the Internet with ARPANet.
    It was German scientists that we snagged. The Russians defected on their own.
    The Brits had every chance to snag those Germans and defectors, and didn't bother. We were smart enough to grab them. You weren't.
    You Brits are remarkably good at designing things on paper, yet remarkably bad about building those same objects...
    Enough is enough.
  14. #34
    Feb 1st, 2007
    Quote Originally Posted by Donington View Post
    Sorry, Jagwaaaaars
    Yes, and the only ones that aren't total unreliable heaps are half GM (my Series III, from the factory) or half Ford (my XKR).
    How's that native-owned car industry doing these days?
    Enough is enough.
  15. #35
    racingfan1 has shifted into fifth gear! racingfan1 has shifted into fifth gear! racingfan1 has shifted into fifth gear! racingfan1 has shifted into fifth gear! racingfan1 has shifted into fifth gear! racingfan1 has shifted into fifth gear! racingfan1 has shifted into fifth gear! racingfan1 has shifted into fifth gear! racingfan1 has shifted into fifth gear! racingfan1 has shifted into fifth gear! racingfan1 has shifted into fifth gear! racingfan1's Avatar
    Feb 13th, 2007
    Hendersonville, TN USA
    Before you get too smug with that statement, ours isn't doing too well either, infact the only ones that are doing any good at all are the Japanese and German, not American.
  16. #36
    MakotoS13 is idling in neutral MakotoS13's Avatar
    Feb 16th, 2007
    Texas, USA
    yeah but... we got the bombs. F em
    SHIFT_bornINjapanMADEinAMERICA
  17. #37
    Feb 1st, 2007
    Quote Originally Posted by racingfan1 View Post
    Ours may not be doing too well... but we actually still have one - GM and Ford are American, not foreign owned.
    All the "major" Brit names are out of business, owned by Americans, or owned by (haha) Germans.
    Enough is enough.
  18. #38
    SuperStalin has shifted into second gear SuperStalin has shifted into second gear SuperStalin has shifted into second gear SuperStalin has shifted into second gear SuperStalin has shifted into second gear SuperStalin has shifted into second gear SuperStalin has shifted into second gear SuperStalin has shifted into second gear SuperStalin has shifted into second gear SuperStalin has shifted into second gear SuperStalin has shifted into second gear SuperStalin's Avatar
    Feb 19th, 2007
    ...and the fact that someone who has the same passport as yours
    owns a large corporation is making you proud... why exactly?
  19. #39
    Feb 1st, 2007
    And the fact that almost *all* your native industries are owned by foreigners doesn't bother you.... why exactly?
    Enough is enough.
  20. #40
    Feb 19th, 2007
    I'm not British, not even close.
    Besides, god only knows who actually owns modern corporations,
    who influences the decisions they make, who takes the money they make etc. etc.
+ Reply to Thread
Page 2 of 4
  1. Found a dejected Reliant Robin collection in Maine, US.
    By Bubs360 in forum General Automotive
    Last Post: February 12th, 2007, 2:52 AM
  2. A Tank with an interesting history.
    By Blind_Io in forum Off-Topic
    Last Post: January 18th, 2007, 6:15 AM
  3. JC vs Challenger II tank in Battlefield 2
    By FireFox in forum Entertainment
    Last Post: October 4th, 2006, 12:33 AM
  4. smashed M5 E60(update) and another update, all seperate post
    By freerider in forum General Automotive
    Last Post: June 2nd, 2005, 2:22 PM
  5. Seperate Forums?
    By Viper007Bond in forum The Site Itself
    Last Post: January 1st, 2004, 3:24 PM
