Nope how would I do that?
Edit: Here's the pic of the driver which seems to be running fine http://img158.imageshack.**/img158/7933/44244810gb4.th.jpg
I had a look in BIOS but there was no audio option as far as I could tell.
Here's the directx diagnosis.
System Information
Time of this report: 12/11/2007, 21:17:45
Machine name: ANANT
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: P35-DS3L
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz (2 CPUs)
Memory: 3070MB RAM
Page File: 378MB used, 4578MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file nv4_disp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Display Tab 2: The file nv4_disp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GTS
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_22511682&REV_A2
Display Memory: 640.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.5819 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 4/12/2007 19:44:00, 5433216 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 4/12/2007 19:44:00, 6738656 bytes
Device Identifier: {D7B71E3E-42D3-11CF-8963-5A0203C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0193
SubSys ID: 0x22511682
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor Max Res:
WHQL Logo'd: No
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x0193
Revision ID: 0x00A2
Revision ID: 0x00A2
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Logitech Gaming Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC221
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: G15 Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC222
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2936
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/23/2001 16:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 00:58:36, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 00:58:34, 24576 bytes
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x041E, 0x1051
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/4/2004 03:05:44, 23040 bytes
| Driver: mouhid.sys, 8/23/2001 16:00:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection 3 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
FS2000 (DX7) - Registry: OK, ExeFile: fs2000.icd (7.00.0000.4781)
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 233.1 GB
Total Space: 305.2 GB
File System: NTFS
Model: WDC WD3200AAJS-00RYA0
Drive: D:
Model: HL-DT-ST DVDRAM GH20NS10
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:54, 49536 bytes
Drive: E:
System Devices
Name: Intel(R) G33/G31/P35 Express Chipset PCI Express Root Port - 29C1
Device ID: PCI\VEN_8086&DEV_29C1&SUBSYS_00000000&REV_02\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
Name: Intel(R) G33/G31/P35 Express Chipset Processor to I/O Controller - 29C0
Device ID: PCI\VEN_8086&DEV_29C0&SUBSYS_00000000&REV_02\3&13C0B0C5&0&00
Driver: n/a
Name: Intel(R) ICH9 Family PCI Express Root Port 5 - 2948
Device ID: PCI\VEN_8086&DEV_2948&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E4
Name: Intel(R) ICH9 Family PCI Express Root Port 4 - 2946
Device ID: PCI\VEN_8086&DEV_2946&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E3
Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E0
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_A0021458&REV_02\3&13C0B0C5&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 17:07:18, 138752 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_50061458&REV_02\3&13C0B0C5&0&D7
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 02:56:44, 7168 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_50061458&REV_02\3&13C0B0C5&0&EF
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D2
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D1
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D0
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_50041458&REV_02\3&13C0B0C5&0&EA
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_50041458&REV_02\3&13C0B0C5&0&E9
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_50041458&REV_02\3&13C0B0C5&0&E8
Name: Intel(R) ICH9 Family SMBus Controller - 2930
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_50011458&REV_02\3&13C0B0C5&0&FB
Driver: n/a
Name: Intel(R) ICH9 2 port Serial ATA Storage Controller 2 - 2926
Device ID: PCI\VEN_8086&DEV_2926&SUBSYS_B0021458&REV_02\3&13C0B0C5&0&FD
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Name: Intel(R) ICH9 2 port Serial ATA Storage Controller 1 - 2921
Device ID: PCI\VEN_8086&DEV_2921&SUBSYS_B0021458&REV_02\3&13C0B0C5&0&FA
Name: PCI standard ISA bridge
Device ID: PCI\VEN_8086&DEV_2918&SUBSYS_00000000&REV_02\3&13C0B0C5&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 16:00:00, 35840 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_92\3&13C0B0C5&0&F0
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_197B&DEV_2368&SUBSYS_B0001458&REV_00\4&24C54F4F&0&00E3
Name: Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_01\4&345CAFAF&0&00E4
Driver: C:\WINDOWS\system32\DRIVERS\Rtenicxp.sys, 5.666.0301.2007 (English), 3/1/2007 12:05:38, 90496 bytes
Name: NVIDIA GeForce 8800 GTS
Device ID: PCI\VEN_10DE&DEV_0193&SUBSYS_22511682&REV_A2\4&1A9C9F1A&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 6738656 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 5433216 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 163908 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 344064 bytes
Driver: C:\WINDOWS\system32\nvucode.bin, 4/12/2007 19:44:00, 929744 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 6668288 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 8429568 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11089 (English), 4/12/2007 19:44:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 6217728 bytes
Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 5439488 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 3289088 bytes
Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 3235840 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 458752 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 1101824 bytes
Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 2854912 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 3538944 bytes
Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 3645440 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 2273280 bytes
Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0011.5819 (English), 4/12/2007 19:44:00, 2387968 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 4/12/2007 19:44:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 4/12/2007 19:44:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 4/12/2007 19:44:00, 37888 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 4/12/2007 19:44:00, 37888 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 16:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 16:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 16:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 16:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:05:44 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 16:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 02:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 02:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 20480 bytes
qasf.dll: 10.00.0000.3650 English Final Retail 10/11/2004 11:20:30 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:26 733696 bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:46 1287680 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 02:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 02:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 02:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 02:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 02:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 02:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 02:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 02:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:46 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 03:05:44 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:58 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:05:44 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:48 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,4.10.0005.0000
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
PP PCM Wrapper,0x00200000,1,1,ppPCMEnc.ax,1.01.0000.0321
PP MPEG-1 Splitter,0x00200000,1,2,ppM1Splter.ax,2.02.0000.3710
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,2.01.0001.0000
Nero Subpicture Decoder,0x00400000,1,1,NeSubpicture.ax,4.10.0005.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
CT Upsampler filter,0x00100000,1,1,Upsample.ax,2.00.0005.0000
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.10.0005.0000
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,4.10.0005.0000
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,4.10.0005.0000
CyberLink Editing Service 3.0 (Source),0x00200000,0,2,CLEdtKrn.dll,3.00.0000.1508
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,3.00.0012.0000
PP Video Regulator,0x00200000,1,1,ppResample.ax,2.05.0000.1818
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,3.00.0000.0000
PP YUY2 Deinterlace,0x00200000,1,1,ppDItlYuY2.ax,2.05.0000.2703
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3650
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,3.00.0000.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
BPM Metadata,0x001fffff,1,1,MetaBPM.ax,1.00.0004.0000
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Indeo? video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
PP IDM,0x00200000,1,1,ppIDMF.ax,1.00.0000.3909
CyberLink AudioCD Filter (PDVD7),0x00600000,0,1,CLAudioCD.ax,5.00.0000.4417
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
PP Video Effect,0x00200000,1,1,ppVidFx.ax,1.00.0000.2329
Cyberlink TS Information,0x00200000,1,0,ppTSInfo.ax,1.00.0000.1705
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Decoder (PDVD7),0x00600000,1,1,CLAud.ax,6.01.0000.3613
PP Video Decoder,0x00200000,2,3,ppGenericVSD.ax,6.00.0000.3313
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.03.0001.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
CyberLink Audio Resampler,0x00200000,1,1,ppAuRsmpl.ax,2.00.0000.0905
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00400000,1,1,NeResize.ax,4.10.0005.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
CyberLink Audio Effect (PDVD7),0x00200000,1,1,CLAudFx.ax,6.00.0000.2731
Indeo? video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
SVM Metadata,0x001fffff,1,1,MetaSVM.ax,1.00.0006.0000
PP Dump Dispatch Filter,0x00200000,1,0,PPDumpDispatch.ax,1.02.0001.2412
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
MPEG-2 PSI Reader Filter,0x00200000,0,0,Mpeg2PsiReader.ax,1.00.0000.0004
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Nero AV Synchronizer,0x00200000,1,1,NeAVSync.ax,4.10.0005.0000
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.10.0005.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
PP File Reader (Async.),0x00200000,0,1,ppReader.ax,2.00.0000.0812
PP Snapshot Filter,0x00200000,1,0,ppSnapshot.ax,1.00.0000.0001
PP Dump Filter,0x00200000,1,0,ppDump.ax,3.00.0000.3322
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.10.0005.0000
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.10.0005.0000
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,4.10.0005.0000
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.10.0005.0000
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.10.0005.0000
CyberLink SAC Video Decoder(PDVD7 HomeNetwork),0x00200000,2,3,CLVSD.ax,6.00.0000.2122
PP DV Buffer,0x00200000,2,0,ppDVBuffer.ax,2.00.0000.1610
CyberLink DV Buffer,0x00200000,0,1,ppDVDump.ax,2.00.0001.0002
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.10.0005.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.10.0005.0000
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.10.0005.0000
Nero Overlay Mixer,0x00200000,1,1,NeOverlayMixer.ax,4.10.0005.0000
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Nero MP4 Splitter,0x00600000,1,1,NeMP4Splitter.ax,4.10.0005.0000
PP DDR,0x00200000,1,0,ppRender.ax,2.00.0002.0026
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Nero Video Decoder HD,0x00400000,1,2,NeVideoHD.ax,4.10.0005.0000
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
HighMAT and MPV Navigator Filter,0x00200000,0,3,HMNavigator.ax,4.10.0005.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2180
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.10.0005.0000
PP TL MPEG Splitter,0x00200000,1,2,ppTLMSplter.ax,3.01.0000.1704
CyberLink Demux (PDVD7),0x00602000,1,0,CLDemuxer.ax,1.00.0000.4528
CyberLink MPEG Splitter(Scramble),0x00200000,1,2,CLSplter.ax,3.01.0000.1424
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP M2V Writer,0x00200000,1,0,PPM2VWriter.ax,1.03.0000.2523
CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.1725
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.10.0005.0000
PP DV TCR,0x00200000,1,1,ppDVTCR.ax,2.01.0000.2910
Creative VideoCrop Filter,0x00200000,1,1,CTVidCropFilter.ax,1.00.0004.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.10.0005.0000
Cyberlink Sub-Picture Filter,0x00200000,1,1,CLSubPic.ax,3.00.0000.0728
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0003.0000
CyberLink Line21 Decoder (PDVD7),0x00200000,0,2,CLLine21.ax,4.00.0000.6929
PP DV Reader Filter,0x00200000,0,1,ppDVMRd.ax,1.02.0009.0021
PP Audio Encoder,0x00200000,2,0,ppAudEnc.ax,2.00.0000.3516
MPEG-2 Stream Reader Filter,0x00200000,0,0,Mpeg2StreamReader.ax,1.04.0000.0000
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.00.0000.0907
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.10.0005.0000
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,3.01.0003.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
Nero Video Renderer,0x00200000,1,0,NeVideoRenderer.ax,4.10.0005.0000
PP MPEG Muxer,0x00200000,2,1,ppMpgMux.ax,5.00.0000.2820
Nero PresentationGraphics Decoder,0x00600000,2,1,NeBDGraphic.ax,4.10.0005.0000
CT PDP filter,0x00100000,1,1,PDP.ax,1.00.0008.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
CyberLink Frame Parser,0x00200000,2,0,CLFParser.ax,2.00.0000.0616
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,14,NeDVD.ax,4.10.0005.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Nero InteractiveGraphics Decoder,0x00600000,1,1,NeBDGraphic.ax,4.10.0005.0000
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
CyberLink Push-Mode CLStream (PDVD7),0x00200000,0,1,CLStream(PushMode).ax,1.00.0000.1524
CyberLink Audio Decoder (PDVD7 UPnP),0x00200000,1,1,CLAud.ax,6.00.0000.1803
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
Nero Sound Processor,0x00200000,1,1,NeSoundProc.ax,4.10.0005.0000
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.10.0005.0000
CyberLink Audio Spectrum Analyzer (PDVD7),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.10.0005.0000
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,3.00.0002.0000
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0002.0000
Creative Audio Gain Filter,0x00200000,1,1,AudGain.ax,1.00.0000.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3650
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.10.0005.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
CyberLink Demultiplexer,0x00200000,1,0,ppDemuxer.ax,1.00.0000.3322
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,3.00.0002.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Audio Decoder 2,0x00600000,1,1,NeAudio2.ax,4.10.0005.0000
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.10.0005.0000
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
PP YUY2 Sub-Sampling,0x00200000,1,1,ppSubYUY2.ax,2.05.0000.2628
Nero FLV Splitter,0x00600000,1,1,NeFLVSplitter.ax,4.10.0005.0000
CyberLink Video/SP Decoder (PDVD7),0x00602000,2,3,CLVsd.ax,6.00.0000.3614
Nero Stream Buffer Source,0x00200000,0,0,NeSBE.ax,4.10.0005.0000
CT HPVirtualizer filter,0x00100000,1,1,Virtual.ax,1.00.0000.0000
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.10.0005.0000
PP Audio Effect,0x00200000,1,1,CLAudFx.ax,6.00.0000.1223
PP WAV Dest,0x00200000,0,0,PPWavDest.ax,1.00.0000.0002
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
PP Audio Decoder,0x00200000,1,1,claud.ax,6.00.0000.3403
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink DVD Navigator (PDVD7),0x00600000,0,3,CLNavX.ax,7.00.0000.2515
CyberLink TimeStretch Filter (PDVD7),0x00200000,1,1,clauts.ax,1.00.0000.4024
PP MPEG-2 Splitter,0x00200000,1,2,ppM2Splter.ax,2.02.0000.3710
Cyberlink Scene Detect Filter,0x00200000,1,1,ppScnDt.ax,1.00.0000.0813
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Creative MP3 Source Filter,0x00400000,0,1,Mp3SrcSP.ax,1.01.0001.0000
Cyberlink SubTitle Importor (PDVD7),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.10.0005.0000
PP Audio Noise Reduction (CES),0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.1415
Nero Deinterlace,0x00200000,1,1,NeDeinterlace.ax,4.10.0005.0000
CT CMSS3 filter,0x00100000,1,1,CMSS3.ax,3.00.0013.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
PP Gate Filter,0x00200000,1,1,ppGate.ax,1.00.0000.0001
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.10.0005.0000
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo? audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
PP DV Dump Filter,0x00200000,1,0,ppDVDump.ax,2.00.0001.0002
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
CyberLink MPEG-4 Splitter (PDVD7),0x00600000,1,2,clm4splt.ax,1.00.0000.3229
Creative PCM Raw Writer,0x00200000,1,0,RawWrit.ax,1.00.0000.0000
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0002.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.10.0005.0000
Nero Video Decoder,0x00600000,2,1,NeVideo.ax,4.10.0005.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Nero Sound Switcher,0x00200000,1,1,NeSoundSwitch.ax,4.10.0005.0000
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,3.00.0010.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.10.0005.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
PowerProducer Double Tee,0x00200000,1,2,ppDoubleTee.ax,1.00.0000.1224
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Nero Thumbnail Decoder,0x00600000,1,1,NeBDThumbnail.ax,4.10.0005.0000
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,3.01.0000.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.10.0005.0000
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.3328
PP SnapShotTIP Filter,0x00200000,1,1,ppSShot.ax,1.00.0000.1905
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.10.0005.0000
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.10.0005.0000
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.10.0005.0000
Nero Ogg Splitter,0x00400000,1,1,NeOggSplitter.ax,4.10.0005.0000
Nero DVD Decoder,0x00600000,2,1,NeVideo.ax,4.10.0005.0000
PP Video Stabilizer,0x00200000,1,1,CLVideoStabilizer.ax,1.00.0000.1017
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.10.0005.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero MP3 Encoder,0x00200000,1,1,NeMp3Encoder.ax,4.10.0005.0000
PP Byte Counter,0x00200000,1,1,ppByteCounter.ax,1.00.0000.1224
CyberLink AVI Audio Time Regulator,0x00200000,1,1,AVI_AudTR.ax,1.00.0000.1515
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,3.00.0002.0000
PP MPEG Video Encoder,0x00200000,1,1,ppVidEnc.ax,6.00.0001.2714
CyberLink Demux (PDVD7 UPnP),0x00200000,1,0,CLDemuxer.ax,1.00.0000.3421
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.10.0005.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.10.0005.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
HighMAT/MPV Navigator Client Filter,0x00200000,0,0,HMNavigator.ax,4.10.0005.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.10.0005.0000
PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.2212
CyberLink Streamming Filter (PDVD7),0x00200000,0,1,CLStream.ax,1.01.0000.1524
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
Indeo? video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo? video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo? video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo? Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo? video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
Realtek HD Digital input,0x00200000,1,1,,5.03.2600.2180
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,2,1,,5.03.2600.2180
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
CyberLink Audio Renderer (PDVD7),0x00200000,1,0,cladr.ax,6.00.0000.2812
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
