STrRedWolf
Okay, imagine if you will, this.
Your friend has gotten a Koenisegg CCX... and modified it. He's lightened the engine yet retained it's power; infact, he's increased it to 1280 bhp. He's also made it doubly fuel efficient by not only adding an electric motor (making it a hybrid) but also making the engine operate in sections (V4/V6/V8). He's then covered the painted surfaces with a thin layer of goo that actually acts like a solar panel, yet gets more power -- so the electric motor most of the time isn't powered by the petrol engine. The interior isn't changed save for that the center controls are via a touch screen. He's also recreated the Prodrive P2 steering and traction controls, and improved the anti-lag by using an electric fan instead of spraying petrol into the exhaust. The changes in weight are none. The exterior styling hasn't changed ether (except what looks like to be an orange paintjob, but that's the goo under the clear coat).
And your envious.
You have access to the same technology he does, but you have a bit more experience. You also have access to better cooling technology, which readily convert heat into electricity. You're much richer than he is. And you think the Veyron's just too damn heavy, so that's out.
Which car would you choose as the base for your ultimate hypercar?
I'm half tempted to choose Aston Martin's DB9 merged with the tech behind the DBR9 (which got 1:08 around the track).
And your envious.
