MattD1zzl3
2 Slow 2 Noisy
- May 6, 2007
- Location
- Miamishire
- Car(s)
- 1996 & 2003 Mazda Miatas, 1995 Chevy Camaro Z28
Im already 20bux over budget. Is the dual core really that bad?
600 bucks, absoute max. I'd rather it be much less than that if possible. I do not need a monitor, i can live without a DVD drive and hard drive. (id like to get all new parts if possible to have a "clean slate"
I really really like the case above, so i will be getting that, anything else is flexable.
Yea, i've already got windows 7 i can use again. Take that off FOR MORE POWAH!
I've already got a 500GB SATA drive i should be able to re-use as well. One more try on the list with this updated info? You seem to know a lot more than me
EDIT: That video card doesnt even support directx 11!!!
Alright then, I went over by $2. However, this is what I would build for that budget. I had to axe the DVD burner though.
Case: Raidmax Smilodon
PSU: Forton 500WATT (You said you might do dual video cards in the future. This was the least expensive "good" PSU I could find that has two PCI-E rails.)
CPU: AMD X4 620 2.6GHz (It's a quad core, trust me, you want one. It will also out perform that i3.)
MOBO: ASRock 770 (It's inexpensive and it's good.)
RAM: A-Data 4GB Dual Channel Kit
KBM: Logitech USB Wireless
Video: Ati Radeon 5770 (It's now in your budget, does DX11, and it will make a mockery out of the one you had listed before.)
Total comes to $589.
That would be my suggestions with the short time I spent researching.
I dont need crossfire if i can get more performance for cheaper now. I dont need to get a new operating system, monitor, keyboard, mouse, or any hard drive smaller than 500GB.
Also, are all you guys with badass computers laughing your asses off at these cheap old parts? haha.
On a budget, a more powerful 4 series card is still better than a weaker 5 series card, even without DX11. I wouldn't take that into too much consideration.
This is a good build, I definitely agree with this. Keep in mind though this mobo only has one PCI-E 16x slot, so you will not be able to crossfire in the future.
Edit: This board is cheaper and you will be able to run Crossfire in the future, but it doesn't have USB3.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176
The 4850 or 5770 are enough for today's games, but I would definitely get a mobo with two PCI-E lanes just in case you need to upgrade. Also if you're likely to Crossfire 5770 in the future then I would suggest getting a slightly beefier PSU. This Antec 550w has triple 18A 12V rail (the FSP 500W only has dual), so it should be enough to power two 5770s, and it's the same price as the FSP 500w.
http://www.newegg.com/Product/Produ...03941&cm_re=antec_550w-_-17-103-941-_-Product
Good build for sure. The keyboard is kinda lame, but it does type fairly nicely and as long as you want wireless it's a decent set for the price, though the range is bad enough that you might as well have wired in that respect. Of course this was when I had one at work about a year and a half ago, so it might be a bit better now.
I would go with the 5770 over the 4850, especially when he wants to Crossfire later on. It's going to be hard to find a 4+ year old card in 2 years when he decides to Crossfire. But it should be relatively easy to find a 1-2 year old card.
If the keyboard/mouse is dropped, will a 5850 make it in under budget?
Polygon you are seriouslythe manbored.
