YF19pilot
Welcome to the second session of Cars 101! If you missed last week's be sure to read up, because today's lesson is related:
http://forum.finalgear.com/viewtopic.php?t=9421
So, now that you know how engines work, it's on to today's topic:
2-stroke, 4-stroke, 6-stroke, rotary, and other ways to go fast
Today's lesson is about different ways for engines to work. I'll be providing some sketches that will hopefully give you an idea of how things work.
You didn't give us a diagram last week! What does a 4-stroke engine look like?
Well, here it is:
I drew the cylinder mid way through the intake downstroke, the dashed lines mark roughly where Top Dead Center and Bottom Dead Center are located. So, now that we know what the basic car engine looks like:
Okay, I've heard of a two-stroke before. How's that work?
First, here's a sketch of a common two-stroke engine:
A two stroke engine does what a four stroke does, only once up and once down to complete a cycle. Two stroke engines generally don't have valves or lubercation systems, thus meaning less moving parts and more power effeciency. I did draw in a small flap on the intake -- this valve flap is to prevent back flow during the engine cycle.
Two stroke engines are commonly found in small applications like lawn mowers and rc cars. Their advantage comes from being able to produce more power from the same amount of space as a four-stroke, and being able to operate in any orientation (handy for chainsaws).
The disadvantage, is that due to the lack of lubercation, you have to mix a special light-weight oil with the fuel. The oil tends to be costly, and two strokes tend to be less reliable than four-stroke engines. Also, because two strokes burn oil, they are more pollutant, and sometimes leaks gasoline because of the lack of exhaust valves.
So what is this 6-stroke you're talking about?
The six stroke engine is an invention by an Austrailian farmer. It replaces the valve system of a 4-stroke with a 2-stroke engine. Here's a quick diagram to give you an idea:
This set up is said to deliver more tourqe and also more power effecency from the traditional 4-stroke. The inventor claims the engine can be revved to 20,000 rpm, theoretically.
Okay, my friend has a Mazda RX-8 and says it has a "rotary" engine. How is that different from a 4-stroke engine?
It's entire construction is different. First, some pictures:
(sorry, didn't have a proper diagram)
The rotary engine is an alternative engine that has actually seen mass production. Credit is given to Felix Wankel, of whom it is often named after (Wankel engine or Wankel rotary).
The triangular shaped rotar spins counter-clockwise, performing the same steps as a 4-stroke engine, as it rotates. The rotary engine offers a light-weight alternative that has fewer moving parts.
However, the rotary engine makes a distinct sound (that some find unpleasent) and tends to be finicky when performing tuning upgrades (like a turbo charger). Also apex seals are known to go bad. Apex seals are used to seperate each stage -- because at any given time, the rotary cylinder is undergoing three stages at the same time.
So what other kinds of engines are there?
There are other types of engines which even myself am still unfamiliar with. For example, there's the ReveTech engine, round engine, and ring motor (a variation of the round engine).
You can visit the ReveTech website at: http://www.revetech.com
The round engine website is located at: http://www.roundengine.com
Currently the ring motor website is down.
You can read more about the 6-stroke here: http://www.jack-brabham-engines.com/
Also, more explanation about the rotary engine can be found on the forum here: http://forum.finalgear.com/viewtopic.php?t=8265&highlight=
which includes a link to the following article (which has moved to this link): http://www.myrotarycar.com/portal/forum/forum_posts.asp?tid=16
Also, picture source for rotary engine: http://travel.howstuffworks.com/rotary-engine.htm
Also, if anyone has some animated gifs, they will be appreciated.
Next week's topic: Carburators and Fuel Injectors
Well, here it is:
