JCE
- Apr 12, 2005
- Location
- DFW Texas
- Car(s)
- 2016 Dodge Charger RT / 2015 Jeep Renegade
If one were to say want to swap an engine from another car into a project car you own what is the best way to get the new engine mounts fabricated? Lets say for argument the engine you want to swap in is actually has less cylinders and much less displacement (obviously). Also your project car is RWD and the engine wanting to be swapped in was both used in FWD and RWD applications.
Few specific questions...
This is assuming you already have an adapter plate that will allow you to use the existing transmission and thus use the engine drive line back from the transmission. I'm just asking about engine mounts here but what else should one worry about in the engine bay in regards to the fitment?
There is a good reason why I'm asking this question...
- What do you need to get started?
- What and how would you measure?
- How would you give this information to a machine shop to make the mounts?
- Should you just pay for someone to do it for you and save the headache if you have zero skill in this area?
