hansvonaxion
If the tech doesn't suit Spectre's immediate needs, it's useless and logic be damned.
Actually yes, from memory they both add up to 100 litres. So that adds up to around 10.4l/100km, which makes sense (for extra-urban driving anyway).
I think a decent range for a long-range electric car would be 400-500km, if it is to take only 5-10 minutes to recharge. Thats the same as many cars with normal sized fuel tanks
More like, does it at least do as much as the thing it's supposed to be replacing does? If the answer is no, it's useless.
Not exactly.
Yesterday evening I already asked myself why I, again, posted in a thread like this at all. This can not end well, and the past has shown there is little point in discussing these things with Spectre. I'm done here. Narf: best of luck!If the tech doesn't suit Spectre's immediate needs, it's useless and logic be damned.
So... if you own a sniper rifle and you buy a shotgun it's useless, because the shotgun has shorter range?
Funnily enough my estate can make do with 55l to go 850km... and it's a petrol, not a diesel.
Charging batteries in 5-10 minutes will not work. Going 400km in a Tesla takes about 10kWh, more in a real car - let's say 15. Putting 15kWh into a battery in 10 minutes would not only require a 100kW plug (for reference, a 3x16A cooker plug delivers about 11kW, not even a 3x63A plug used on building sites, concerts, theatres etc. would suffice, you'd struggle with 3x125A). It would also heat the battery tremendously, if not break it.
The new XJ has worse range than your old one.
Hey, they're setting the expectation, so they should be evaluated against it.
Charging batteries in 5-10 minutes will not work. Going 350km in a Tesla takes about 70kWh off the plug, more in a real car. Putting 70kWh into a battery in 10 minutes would not only require a 420kW plug (for reference, a 3x16A cooker plug delivers about 11kW, a massive 3x125A plug used for powering live concerts etc. delivers about 86kW. In other words, you would need five of those). It would also heat the battery tremendously, if not break it.
How do the storage systems work into that scenario? I remember reading that here they have a fast charge system that uses batteries to store the charge. I believe they said 5min charge.
To me using batteries to charge batteries sounds like a bad idea. Might as well have two battery packs for your car and swap in your garage.
Got any source on that 5 minute charging system?
Here's an article that links to one of them: http://reviews.cnet.com/8301-13746_7-20009762-48.html
That 600km range is more than an A3 petrol urban cycle.
capacitor based systems
Weee, 50 miles of charge in 5 minutes. More marketing half-truths there :lol:
