Vitamin J
- Jul 11, 2006
- Location
- Denver, CO
- Car(s)
- 1996 Mazda Miata 1.8L, 1992 Spec Miata 1.6L
HP/L is one of the stupidest arguments one can make about an engine. It doesn't show you the awesome torque and hp curves like this:Yeah Z06 is a good car (and its amercian, wow ). I say its still ridiculous that 7 liter and it only puts out 519 hp (stock). I just dont get the point of this engine.
Also, HP/L also depends a lot on engine size and max rpm. A 7L LS7 making 519hp at 6800rpm is just as impressive as a 1.3L Hayabusa engine making 195hp at 13,000rpm.
For more comparison, the S54 M3 I6 weighs over 600lbs, the RB26DETT weighs over 700lb and the 2JZ-GTE weighs over 750lbs. The Enzo V12 also weighs over 600lbs. Not to mention the physical size of pushrod engines allows them to be mounted low and far back."The LS7 weighs 458lbs dry, the BMW M5 V10 weighs 528lbs dry."
True... :?
Tiff Needel says it's fine on the road. Clarkson may have a point, but its hidden behind years of hate for Corvettes.And personally, I think the Z06 is an amazing car...What was Clarkson's only complaint, that he thought it was too much of a track car for the street? That only makes me want it more; comfort is at the bottom of my priorities list.
Cam changes usually only gain 30 to 50hp with everything else stock, this gains almost 100hp.those are some good numbers for a cam change
I dont even think FI would be the way to go with the LS7, just a feeling
Also, 11:1 comp ratio is bad for boost.
The thread is not for that at all, if you want to see how good the LS7 is, watch Lemans.It's close to happening. But what can you expect for a thread that could be basically titled "Look how good our american engine is".
This motor wouldn't be nearly as driveable with that much horsepower. What pushrods gain in torque and power, they lose is drivability with hot cams.That potential just tells me that GM saved up on parts and decided to take less power instead of using the full potential. That is pretty much the essential difference between american and euro/jap engineering. If it were a euro/jap engine it would have all those aftermarket parts as stock, it would make 800hp+ and it would cost twice as much
The LS7 is basically the C6R's motor with a cooler cam, less compression, and some catalytic converters. The C6R makes well over 800hp N/A without restrictors.
ITBs don't = better response, they can help, but there's much more to it. Reciprocating mass plays a bigger part in response.Ok, I see the point of it. Still, I dont like it. I dont agree with throttle respose though. As I can see on the pic posted on the first page, there are no Individual Throttle Bodies. Dunno, maybe there is, but I cant see it on the pic. M3 has got Individual Throttle Bodies, thats why it has ultimate throttle response.
