So, do I have the choice to actually WANT a small engine that revs high and only produces power at 7.000rpm? You are being just as idiotic. The LS7 is a great engine, no doubt about it, but what about taste? I LIKE small, revvy engines. I LIKE changing gears, I LIKE to squeeze out every last rpm of the engine. No wonder drivers in the USA love automatics and Harleys. And please note that I never said they're crap, I do like them, it's completely different.That's why i hate european and japanese engines..
no power until you get it revved up to 7K rpm.. and then the power band is only 1000rpm wide.. takes 5 seconds to rev from 1000rpm to 7K because it needs a heavy flywheel to have any momentum or else it will stall on a hill, and big arse turbos to force the necessary air in to burn the fuel required for decent hp.. frickin sewing machines..
that ls7.. 450lb-ft of torque at 3K rpm.. .. the area under the torque curve is what matters, not a buzzy high water mark at 7K rpm.. unless you've got a cvt.. but really.. who wants to race with a cvt?
exactly, mass and proper rod ratio = good response..
LS7 is a street legal emission approved motor for mass consumption.. it has to be reliable, and unlike ferrari engines or other hyper exotics, uses normal oil, don't require $7500 of maintenance at 30K intervals, and generally designed to last atleast 100K miles (160K km) before any major maintenance
and if you DO blow up the motor.. you walk into any GM dealer.. tell them you want part # 17802397, drop about $13K USD (about 9,900 euro) on the counter and have it drop shipped to your garage.. and be good for another 100K miles.
$/hp = $26USD / hp
your average turbo kit for an import engine.. your looking at $5K or so.. for what.. 100~150hp boost? mostly unreliable at that.
or more than $50USD/hp
a 550 maranello engine will run you $75K USD for 485hp.. or $136USD/hp BIG difference.. on an engine that requires major service at 30K
Oh please, Ferraris are more than an engine, and you know it. Calculating $/hp is just as stupid as Hp/Liter.
