rowd22
staying in gear will make sure your wheels don't lock up
Although it does reduce the chances of your wheels locking up, it will not stop them doing so, especially in wet/oily conditions.
Right, ABS is what stops wheels from locking up under braking. Engine braking can actually cause the wheels to lose traction, depending on the conditions and how it's done.ABS makes sure the wheels don't lock up?
"Engine braking" is also called "compression braking". Cars with greater compression are more sensitive to more engine braking - a lighter car with low compression will likely exhibit less engine braking than a heavier car with high compression.I agree with narf, lighter cars are more sensitive to engine braking
get the most braking force possible in that situation.
*nod* This. When I use "compression braking" on the track, I'm not using it in the place of the brakes or to assist the brakes. I'm using it to cause weight transfer to the front so that the rear will slide. The goal isn't to slow the car efficiently, but rather to cause slip. The compression braking results in some slowing, which causes the weight transfer, which causes the slip I need. I'm actually using compression braking instead of the actual brake system because the compression braking is so weak compared to the brakes - I want just a slight slow as weight transfer is caused, not actual braking.Braking performance is limited by tyres, not the brakes. Adding the engine doesn't make you stop faster, your pads/discs can generate massively more friction on their own.
ABS makes sure the wheels don't lock up? Oh, and if Zesty's car is too light... shouldn't the effect of engine braking be even greater?
I'm curious about something. My Honda is the first high revving manual car I've owned and it's taken me quite a long time to get use to it. All my other manual cars made most of their power lower in the rev range, so getting off the line is easy enough. But with the SI I have to give it some revs when taking off from a stop.
Anyway, my question is do high revving motors go through clutches faster than cars that make their power at low revs?
