News: MegaSquirt Engine Management Now Plug-N-Play for over 40 models!!! (ATTN: MIATAS)
Got this in email today, since I bought my MegaSquirt II from DIYAutotune. Seems they now have a plug and play, no additional wiring or components needed (in most cases) ECU replacement based on MegaSquirt that works with more than 40 cars.
http://diyautotune.com/diypnp/index.html
Now Available! The DIYPNP EMS!
Read up on these pages, and kits are ready to ship here in our shopping cart.
Feature packed DIY-oriented PNP EMS System available NOW for a stack of cars, and soon for an even bigger stack.
Acura. Audi. BMW. Dodge. Eagle. Honda. Hyundai. Mazda. Mitsubishi. Porsche. Subaru. Suzuki. Toyota.
The initial targets of the DIYPNP.
DIYPNP - The Standalone PNP EMS for just about anything...
What is a DIYPNP?
(Taken from the DIYPNP FAQ located here)
The DIYPNP is a Do-It-Yourself Plug-N-Play Engine Management System. It is made up of three main pieces that allow for an incredibly flexible and modular system for building a plug-n-play EMS for a plethora of vehicles.
MicroSquirt Module- At it's core, the DIYPNP is based on the MicroSquirt Module which is a MegaSquirt-II Processor based ECU on a credit card sized PCB. The DIY element of this EMS comes from the fact that you assemble it yourself from a kit of components, soldering the unit together and then adding wire jumpers to route the signals to the connectorboard to match the needs of your car. The assembly is not nearly as complex or time consuming as a standard MegaSquirt ECU kit assembly, there are fewer components and all components are sized so that they are easy to solder (no tiny transistors here).
Mainboard- We've taken the awesome capability of the MicroSquirt Module, combined with the MS2/Extra firmware, and built out a mainboard that adds a very nice featureset including pretty much everything we get asked about on a daily basis by our customers. You've got dual ignition inputs and up to four ignition outputs (hi or low current, allowing for Coil-On-Plug for up to a 4cyl engine or wasted-spark ignition for up to a V8 engine. Distributor based ignition is of course supported as well. Knock control, boost control, 4 spare inputs and 4 spare outputs for driving fans, intake butterflies, on/off variable cam systems, whatever else you can imagine. There are more features too, check the features and documentation pages for full details.
Note-- All of the primary Inputs/Outputs are brought out along the edge of the mainboard that lines up next to the connector board.
All common ignition input/output pullups are as simple as they could be with a resistor network in place ready to setup.
Connector Board- And then the last piece you need to know about is the connector board. This is a small PCB that slides into the same slot as the mainboard and lines up right next to it. It's usually not much more than a breakout board for an OEM style connector that often fits a stack of vehicles as many of these connectors were used by multiple manufacturers, and often on multiple vehicles/engine families at each manufacturer. Sometimes we may fit an extra circuit on the connectorboard if we've found that the vehicles that use that connector typically need a particular circuit. An example of this is the Bosch Motronic 55pin connectorboard, which hosts a circuit to control the 3-wire IAC valve that is common in vehicles that use this connector.
So after you handle minimal assembly on the mainboard, you do a bit of research on the harness pinout in your vehicle (or download a spreadsheet of pre-researched info and just check it for accuracy in your application), and you use this info to run a handful of jumper wires from the mainboard to the proper breakout pins on the connectorboard bringing the signals in/out on the proper pins on the connector. This is what makes the DIYPNP so easy to apply to such a broad range of vehicles. It's basically a set of PNP EMS building blocks, with awesome results.
You want boost control, run a jumper to the input and to the output. Turn it on the in the software and tune it.
You want to convert your engine from it's stock distributor to wasted spark or COP, add the proper crank/cam trigger wheels to the engine (you might have what you need already inside of that old distributor) and wire those sensors up to the DIYPNP, then wire the ignition outputs up to your coils, set your timing and tune it.
The flexibility is massive. And if we didn't include a circuit you want, we've got two large proto areas on the mainboard (one is under the uS Module) and in some cases there is a third proto area on the connector board if we had the extra space.
There will be three DIYPNP Models released initially. The N42, the N76, and with maybe a slight delay, the B55 model. These three models will potentially support 40 or more vehicles, and we didn't even research the more obscure stuff out there.
DIYPNP N42 (Nippon Denso Style 42 pin)
Nippon Denso Style 42pin Connector Part# DIYPNPN42-K
Make Model Engines From To Application Docs Startup Map Notes
Toyota 4Runner 22R-E, 22R-TE 1984 1991
Toyota Celica All except 3S-GE and 3S-GTE 1985 1990
Toyota Corolla 4AGE naturally aspirated 1985 1989
Toyota MR2 4AGE naturally aspirated 1985 1989 MS2/Extra 2.1.0
Toyota MR2 5SFE manual transmission 1991 1992
Toyota Pickup 22R-E, 22R-TE 1984 1991
Toyota ECUs that use this connector are generally marked "10T-18T-14T" on the lower edge of the ECU identification sticker.
DIYPNP N76 (Nippon Denso Style 76 pin)
Nippon Denso Style 76pin Connector Part# DIYPNPN76-K
Make Model Engines From To Application Notes Startup Map Notes
Acura Integra All 1992 1995
Acura Legend C32A 1991 1995
Dodge Stealth All 1995 1996
Ford Escort 1.8 DOHC 1991 1995
Ford Probe F2T 1990 1992
Ford Probe KLDE 1993 1995
Eagle Talon 4G63 1995 1998
Honda All All 4 cylinder 1992 1995
Lexus LS400 1UZ-FE 1990 1992
Lexus LX450 1FZ-FE 1996 1997
Mazda 626 KLDE, KLZE 1993 1995
Mazda Miata All 1990 2000
Mazda MX-3 All 1992 1995
Mazda MX-6 F2T 1990 1992
Mazda MX-6 KLDE, KLZE 1993 1995
Mazda Prot?g? All 1991 1994
Mazda RX-7 All 1989 1995
Mitsubishi 3000GT All 1995 1998
Mitsubishi Diamante 6G72 1992 1996
Mitsubishi Eclipse 4G63 1995 1999
Mitsubishi Lancer EVO 4G63 2003 2005
Mitsubishi Mirage 1.8 SOHC 4G93 1993 2000
Subaru Impreza All 1993 1995
Subaru Legacy Turbo 1991 1994
Subaru SVX All 1992 1995
Suzuki Sidekick 1.6 MFI 1992 1995
Suzuki Sidekick All w/ manual transmission 1996 1998
Toyota Celica 3SGTE 1990 1991
Toyota Celica All 1992 1999
Toyota MR2 3SGTE 1991 1995
Toyota MR2 5SFE manual transmission 1993 1995
Toyota Paseo 5E-FE 1992 1997
Toyota Supra All 1991 1992 *Stock DLI module may not be compatible with current firmware.
Toyota Tacoma 2RZ-FE, 3RZ-FE 1995 2000 Does not fit 2000 California model
Toyota Tacoma 5VZ-FE manual transmission 1995 1997
Toyota Tercel All 1991 1998
Toyota ECUs that work with this model are typically marked "26T-16T-12T-22T," often with one or more of these numbers omitted, along the lower edge of the ECU identification sticker.
Note that some models above had computer controlled automatic transmissions - if this is the case for your car, the DIYPNP will not be able to control the transmission beyond control of a basic lock up torque converter. If you have an automatic transmission, please check before ordering.
DIYPNP B55 (Bosch Motronic Style 55 pin)
Bosch Motronic Style 55pin Connector Part# DIYPNPB55-K
Audi S4 all 1992 1994 *Flywheel trigger & 5 cylinder COP may not be compatible with current firmware
Audi S6 all 1995 1995 *Flywheel trigger & 5 cylinder COP may not be compatible with current firmware
Audi Quattro V8 1990 1994 *Flywheel trigger may not be compatible with current firmware
BMW 325 M20 1987 1992
BMW 525 M20 1989 1990
BMW 535 M30 1989 1993
BMW M5 S38 1991 1993
Hyundai Scoupe all 1992 1995
Porsche 911 all 1990 1995
Porsche 944 S2 1989 1991
Porsche 968 all 1992 1995
We'll be quickly following with more models. We're eyeing the connector used on:
* Nissan 240's
* Another (52pin) Nippon Denso style connector used on S4 RX7's, Supercharged 4AGZE MR2's, and Gen2 Supra's
* The 35 pin Bosch Motronic Connector used one a handful of cars, mostly European.
The Miata kit is only $460.
thedguy
Orange California
(OO=[][]=OO)
Friend of mine got his for $400 and that was installed!
I'm planning on going with it in both of my cars when I get around to it (and the funds).
Posmo
'86 Sierra iS, '70 Cortina, '90 Sierra, '04 RS182
I might be putting megasquirt v2.2 on the Sierra sometime. Just needs an EDIS4 box from a mondeo, a few sensors and some wiring. Great systems, and now even more easily acquirable for the common man :)
Posmo, milltek and I have his Series III running on Megasquirt II v3 with EDIS6 (also found in a Mondeo, but we pulled ours from Ford Explorers and Ford Tauruses). We're finished building it and now we're working on the fuelling map.
I strongly recommend not going with MS-I. MS-II is a lot more flexible and intelligent - and easier to use.
Eunos_Cosmo
Oakland
'84 Mazda RX7, '12 Mazda 2, '99 Porsche Boxster
So it looks like its only cars that were originally MAF? Why no 84-88 RX7 megasquirt?!
edit: see they are looking into connectors for the S4...hope it works with the S3.
jasonof2000
Delmarva Peninsula
2013 Lincoln MKT, 2002 Miata SE, 2012 Honda NC700
I'll add this to my list of things to add to my Miata, after a new header and high flow cat.
That said at this moment all the add ons in the world won't be helping me go faster since I'm still learning the car.
Dogbert
Helsinki Smash Rod
N38? 43', W90? 22'
Roger Dean's Rocks
* Nissan 240's
:sad:
thedguy
Orange California
(OO=[][]=OO)
Isn't MS 3 coming out in the not to distant future?
The PNP's are all MS2 v3 right? The only downside is that no matter how well tuned they seem to be, it's damn near impossible to pass smog (sniffer) with 'em. 2 friends of mine tried, spent boat loads of money trying to get a good smog friendly map, and failed.
Oh, you can get a smog-compatible map, but it takes some doing.
They're basically downsized MS2 v3s, yeah. They're actually modified MicroSquirts.
MS3 is due out RSN, but it's been due out RSN for four or five years now....
thedguy
Orange California
(OO=[][]=OO)
Found anyone that has done it? A friend of mine has spent several days with his MS on a stock 1.6l miata and a new cat on a rolling road smog machine trying to tune for better emissions and can't get anywhere NEAR close to within legal limits.
There are quite a few on the MS forums, so it can be done. You need a four gas analyzer to develop the tune, though - not just the smog sniffer.
Zagreb
'08 Pontiac Solstice GXP
If I could get this (with some pre made maps) for my '88 13B, as well as the manifold/tb/etc for under a grand I'd jump on it.
FoundSoul
Suwanee, GA 30024
Miata, MR2, RX7, Nova, Mustang
We've got a good startup map for our 85 GSL-SE which is a 13B, and though we still offer it as a startup map, that one is well tuned for our car. FYI that is setup with a S4 ignition system, CAS and Coil Packs.
We've also just installed a DIYPNP on a 1990 n/a S5 RX7. Car belongs to a shop owner a couple doors down. We did that on Tuesday and he's supposed to be bringing it back in to us to tune soon. Then we'll have complete pinout and startup map info to post for S5's.
Hey Jerry - good to see you found us. :D Give my regards to Matt - I'm one of the two guys in Dallas that are working on MegaSquirting our old Jaguars.
Let me guess, Google Search?
airmenair
Arlington, Texas, USA
Do you have any plans on releasing one for a Merkur XR4Ti? The whole Merkur community pretty much uses megasquirt already.
_HighVoltage_
Captain Volvo
1998 Volvo S70 T5M
So if I understand correctly, those of us who have computer controlled auto gearboxes are screwed.
