Mending some wire
MadCat360
Mazda Raceway
*Carless* Waaahhh
I have this set of headphones and there's a split in the insulation around the wire. It works fine, but I've been patching it with electrical tape to keep it from getting worse. I would use a heat shrink wrap but it's got one of those big volume dongles in the way.
How should I fix it in a more permanent way?
ahpadt
London
Solder it and then find a shrinking cap/wire to put on top of that.
Luca
is meh.
Vienna, ?sterreich
/me slaps Headphone on store counter
Thats some lousy wire quality sir!
Depending on his mood, the mood of his employer, and the mood and general policy of the manufacturer you might get it replaced. Except if it's clear you broke it.
narf
Sgt. Maj. Buzzkill
Kiel/Wherever, Germany
'19 BMW M240i
Remove the volume dongle, that's what I did when inevitably some wire broke at the end of the dongle.
MadCat360
Mazda Raceway
*Carless* Waaahhh
ahpadt
London
To make sure the wire was properly mended you would actually have to do that. If you're not very confident in stuff like that you'd be better off with trying to replace the whole wire.
Blayde
Bahrain
'06 Honda Civic EXi, '11 Kia Sportage EX
why not cut 3x length and then cut the shrink tube length wise, heat only on the closed sides and then close it off with electrical tape all along.
MadCat360
Mazda Raceway
*Carless* Waaahhh
I'm definitely not. I've never soldered anything in my life.
Nabster
Has Slutty Mustangs
DFW
Diameter of volume dongle and diameter of wire? Shrink tubing comes in more than factors of 'shrinks to half size'...
MadCat360
Mazda Raceway
*Carless* Waaahhh
The wire is tiny, only 1/8" and the dongle is 3/4".
I'd be really surprised if a shrink tube could shrink that much.
Nabster
Has Slutty Mustangs
DFW
$18.08 for a 4 foot length of 6:1 shrink tubing with an intial diameter of 3/4" here.
MadCat360
Mazda Raceway
*Carless* Waaahhh
Well, I suppose it's a good thing I was lazy and didn't repair the wire. The set just broke. Got brittle, or something, and has a large crack in it that makes it structurally unsound (made semi-sound again with tape).
Time for a Sennheiser. Out with ye, Logitech!
