Ownership Verified: My 1996 NA M-Editlon MX5
cdbob
Edmonton, Canada
'09 STi (soon gone),'04 TDi, '96 MX-5 M
Update:
I'm trying to get this in reliable driving condition again as fast as possible, I'm still waiting on parts to replace the rad. In addition I'm going to be redoing every belt and pulley on the front of the motor, the water pump and clean the lifters.
This week I replaced all the fluids and filters on the car. (Engine oil, trans oil, diff oil, brake fluid, power steering fluid, turret fluid, engine oil filter, air filter, fuel filter)
I also replaced the plugs.
The car ran fine before all this, but I wanted to establish a solid baseline for the car, so I can know exactly where a lot of things sit on it. Since the car is so cheap for parts and so easy to work on, it's different than a car like the STI.
I'm pretty excited for it and have quite a few upgrades planned once I have the sti sold. (Mainly coilovers, ARBs, new bushings in all the somewhat easy places, braided brake lines and frame braces)
Here are some pictures from today showing some of the work I've done. Pictures are from newest to oldest.
Car in the garage
New plugs and wires
Shot of top of the engine after I put the new air filter in (and degreased the entire engine bay)
Hard to see (and get to) new oil filter and the horn remounted (though turned to get to oil filter, since the wheels were not off at the time)
Shot of the diff after the oil change (still a bit left I have to clean off)
Shot of the transmission after replacing the oil
Another shot of the transmission (need to clean the excess oil from filling)
Last brake I did, and all the old brake fluid in the jug
Second last brake I did
Picture of the rear of the car, I have extensively cleaned and polished the car
Interoir back together after doing the oil in the shifter turret
Another picture of the brakes/ suspension, you can see some brake fluid I spilled on the ground
Picture of the current battery in the car (I still need to get a bracket for it and replace it with a gel battery that won't rust the trunk like this one did)
I plan on tackling this rust as soon as I have a new battery and bracket (going to grind all the rust off, prime it and repaint it)
Shot of one of the brakes after being done (as you can see I also need to powder coat the control arms and get some coilovers!)
Another picture of the underside of the car
Collection of different used oil (motor oil and filter in one, diff and trans oil in jug)
Picture of the underside of the car (bottle used for bleeding brakes)
Newer Fluid in Reservoir while bleeding the brakes
Old Brake Fluid in the reservoir
Putting new oil in the shifter Turret
cdbob
Edmonton, Canada
Few more updates, this week I hope to clean out the lifters on the engine and replace the water pump, after I do that I can put the cams back in and put all the belts back on. I've been procrastinating quite a bit on this and I'm going to try and pick up the pace a little bit.
All of these is preventative maintainence, I could easily have not replaced the timing belt, but I opted know exactly the condition of engine rather than not know the condition of the top end of the motor.
New Fuel Filter
And old fuel filter
Drained Coolant out of rad
Plugs and wires coming out
Cam cover studs coming out
Cam cover coming off
Pictures of timing gears at TDC
Cover plate around timing gears coming off
Engine nearish to TDC (before being put to exact TDC)
At first I was going to lock the camshafts in place, but then I decided to clean out the lifters so I just took that whole thing off
Bolts out of cams and some cam bearings off
Picture showing progress on engine at same point
Camshafts removed from engine
Hydraulic lifters removed from engine
Picture showing engine minus cams and lifters
Covering the engine for the night
cdbob
Edmonton, Canada
Old Water Pump
Water Pump out of engine
Madcat noticed my Crank Timing Belt Pulley has a chip in it from the photos, so I pulled it and I''m going to be putting a new one on when it arrives sometime this week.
Chipped Pulley and Keystock
Engine side (Also going to pulling and replacing that seal)
Hopefully I have everything I need to start putting this car back to together. All I have left is to clean the lifters and install the new water pump and I can starting putting her back together.
WDWBen
Subaru Killer
Disney World
2021 Mini Cooper S
Man, I love how the valve covers look on your engine. My NC has tons of plastic crap that makes it look not so pretty.
