bone
"bangle for president"
so my best friends renault 19 suddenly showed a crack in the front windshield. took it to carglass for a new one, they remove the black rubber around the window, and found a lot of rust
if they'd put a new window in, it would crack again within the next month, so it has to be taken care of first
the crack, and on spot of rust (with a hole )
as you can see, it's all the way from left to right
since we're eliminating rust, the hood also need a patch
top-view of the hood
luckily the engine still looks in good shape, as do the seats (men i do love leather seats )
first things first, bye bye hood
the tools, from left to right.
the shiny one, has a sharp point at the bottom, you have to push it under the window, and then pull it down so it cuts through the glue
for the other one you need to get the metal wire through the glue (with the long pin), and then use it like a saw, you attach a handle on each side of the wire.
first try with the smallest tool, but that just resulted in an additional crack
so try the other one; first get the wire through
sawing it
bye bye windshield
maybe we should first clean out this, so we can work inside
70s ford escort
simca
and a caravan
will post pics as we proceed in the repair
sawing it
bye bye windshield
70s ford escort
simca
and a caravan
