WTF?
since when am i building a super seven replica? :lol:, and there aren't that many here working on their car themselve, would be a pretty passive section i think
anyways, here's the proceed
so we were replacing a timing belt, but we have kinda difficulties commiting to 1 job only
when he bought the car, these were in the trunk
so might as well install them.
first get out the original setup, but of course those screws are tight as hell --> abuse them with a torch
gone
quite a lot shorter
looks better than the ugly black springs
that's done, continue with the belt
accessory pulley is gone (tnx to a bouloneuse, impossible to do without)
remove the old belt, align up all the marks (on the crank as well) and slide over the new one (beware of the directionarrows)
after tensioning it, it was time to start the car...and it gave nothing
but before panicking, always take your multimeter
. turned out battery was dead
, it gave 12v, but when trying to start, it fell back to 6, which is way to little
find another car, take out the battery and hook it upt
ever seen such a easy hood? it stands vertically, all the access to the engine you need
with its battery connected as well, it fell back to only 8v
, which is still short of 12v
then put the battery of the xantia back, connect it with the renault and try to start this with the xantia running, still nothing.
we were starting to phreak out by this time, but as a final messurement, we towed it around the block where i live, halfway...VROOOOAAAM... it started
i think it woudn't start right away due to all the oil that was surrounding the spark plugs. some must have dripped in when we took these out (and the spark pluggs realy realy realy need replacement)
the gasket that was leaking oil in the first place still looked ok, but the screw holding the valvecover, could be undone with a simple screwdriver. they were fare from tight enough, we tightened them and hope it won't be spilling any oil no more.
oh yeah, and pic of the new suspension
that doesn't look good, it looks ever worse caus the car is standing half on the sidewalk, but still, i think he'll might to go get some 4cm lowered springs for in the rear
, after all, he did save 700?, that's what it would cost to have the timing belt replaced by an official dealer
EDIT: i have some pics of a banshee 7-plate wet clutch, you might be interested to see this as well
