Problem with [05x05]
Polizei
Toronto, Canada
Hi,
I'm having a real problem with this episode (nov 21 05).
I have played all other episodes I have in Winamp with no troubles.
I'm getting no audio or video.
Here is a screen shot of Gspot.
Thanks for your help guys!
Thanks for the tips guys. Latest xvid didn't do anything but VLC plays the file. I'm happy because I never saw this episode.
Now the problem I have is that NeroVision Express still won't recognize the file so I can't put it to DVD. Any ideas there?
ffdshow with the video for windows drivers option checked could work... (install with all the "vfw" options on...)
http://www.free-codecs.com/download/FFDShow.htm
You actually need to get the vid working in a player that uses direct show, since Nero accesses it that way, I think...
If not, you could open it in Virtual Dub and recompress it with a really high bitrate in the same resolution to proper Xvid or go to mpeg2 right away... That should work for sure... (maybe as a first try in that direction, simply put audio and video on direct stream copy, as it could maybe work as well and only takes a minute or two... If you don't have any idea what I'm on about... Then sorry...)
Buba
Long time since this post but I finally got around to fixing this problem. Thanks for your suggestions Buba.
I installed virtual dub. When I try to open the file I am having problems with I get the error message: "Couldn't locate a decompressor for format 'xvid' (unknown). Virtualdub requires a video for windows compatible codec to decompress video. Directshow codecs such as those used by windows media player, are not suitable."
Maybe this narrows down the problem a bit. I have just installed the latest xvid codec.
It baffles me that nobody else has had this problem.
Thanks for your help!
Same problem with "Top Gear - 2004.11.21.avi"
Thanks !!!!, solution... install the VLC Player, I use the Crytal Player, every time works perfect but this one only can be played with the VLC, don't know why but it works ;) I also have problems with the audio of the ep. Top Gear - 2004.12.05.avi, now it works too !!!
thats weird...when i downloaded 05x05 ir worked flawlessly. but now i wanted to watch it again and at first i was missing the picture in MPC and the sound in VLC. then i got the ffdshow as buba suggested and now i had the picture upside down in MPC...
i'm now converting it via virtualdub... :?
