Not to sound like a jackass but did you actually test that assertion or are you going based strictly on the theoretical limits of the two standards? narf tested USB vs eSATA not USB2 vs 3, those are completely different technologies. There is no eSATA on Apple laptops, never have, likely never will but it's not really exclusive to Apple, my Dell XPS didn't have eSATA either and it would fall into the high end category. No one looking at an Apple laptop would be expecting eSATA capabilities, however since TB is basically an external PCIe interface it would be trivial to make an eSATA to TB adaptor (and I'm sure we will see them pretty soon). That's really the main benefit of TB, it has more than enough bandwidth to support any standard that's out there and while yes it would require an adaptor unlike USB3 or eSATA it would not be limited to just the native protocol***.
***Yes there are translators from USB to SATA/PATA but they still have to do translation from USB to SATA and back, by the sound of it TB would work just like a normal expansion port inside of your PC.
IMO the ONLY bad thing about TB is the fact that instead of the original designs I saw where it would look like a USB port and accept all of the current USB peripherals.
I'm having issues with my new router which made me forget about this discussion, but I still feel like making a reply if I may:
Yes, I know eSATA and USB are totally different and unrelated standards... I also know that eSATA is not really common to any laptops, but I thought we were discussing the new Sandy Bridge-based iMacs.
My initial statement was that the a high-end computer like the new iMac (never mentioned the MBP, not sure where you got that from) needs to have either eSATA or USB 3.0 so a potential customer can have the option of transferring files quicker than the slow speeds offered by USB 2.0 (as TB's not gotten much traction yet). eSATA and USB
are different, but they are related in that they both provide much faster theoretical
and real-world speeds over USB 2.0 drives.
If they make eSATA/Thunderbolt adapters then I guess that's a solution, the Apple faithful are used to buying all sorts of adapters anyway. Still, doesn't excuse Apple's completely stepping over a mainstream technology like USB 3.0 (even though I know Intel is a bit guilty here too).
Oh, and I finally got my USB 3.0 ports working so I can do some tests for you. But I don't think I was making baseless claims before having done these tests because as I was saying, I think theoretical and actual maximum speeds are relative - USB 2.0 drives never came close to reaching 480 MBits, and even though USB 3.0 drives still fail to achieve that speed (let alone the 5GBps theoretical max. of USB 3.0) they are indeed noticeably quicker as you see below.
These tests were done using CrystalDiskMark 3.0.1 and a WD My Passport SE 1TB drive:
https://pic.armedcats.net/s/sh/shawn/2011/05/11/cmdusb2.jpg https://pic.armedcats.net/s/sh/shawn/2011/05/11/cmdusb3.jpg
Admittedly I said three time faster before, but write speed is still more than twice as fast with USB 3.0. To put this into perspective, the 1.43GB 720p rip of Top Gear's Polar Special takes 59 seconds to transfer over USB 2 and 28 seconds using USB 3.0, with only difference in the equation being the port used.
Just for the heck of it I also tested my eSATA enclosure which houses a 750GB drive. Even faster than USB 3.0, but I admit eSATA has certain disadvantages (e.g. needs separate power cable, connections aren't as sturdy):
https://pic.armedcats.net/s/sh/shawn/2011/05/11/cmdesata.jpg
So yes, setting aside everything else theoretical or not, USB 3.0 beats USB 2.0 rather handily. The same would go for eSATA. It would serve many Apple customers well if they had added either of these unrelated interfaces to Macs by now. They would still be useful despite of Thunderbolt being on there and in fact, they could have been added years before Thunderbolt was.
