To get the bobtail Disco through its MOT I had to steal the interior light bulb from Geoff, as it was the night before. I got a pack of 10 from Amazon and went to fit one, however I goofed it and lost it in the roof. Yes, that's right, there's a hole in the roof that the bulb can go through if you have butter fingers.
See, it's got a stupid hole in it! What's that for?
With the lamp unit removed the bracket behind also has a hole in it, what a stupid design!
I felt around but couldn't find the previous bulb, presumably it has fallen down the sides of the roof lining. It won't come off without removing the hardback
and the black piece of trim behind it. So it's staying there for now. I fitted another bulb, it's more fiddly than it needed to be.
Then I checked the dessicant dehumidifier thing in the load area cubby hole and it clearly isn't working properly...
Not exactly sure where that all came from but I vacuumed it all out and dried it as much as I could with a towel. Funnily enough there is still some dessicant in the dehumidifier thingy.
No idea where the water came from, the rear window appears to be sealing and both pop-out rear windows are closed. I'll keep an eye on it.
Finally, having added a second CTEK cable to the solar charge controller so I can have the Mazda and Freelander charging at the same time, I used one of the old tails to give somewhere to clip the cable to when going out in the Freelander. When I had one cable I just plug it in to the Mazda.
I pulled the pins out so it doesn't connect and short out with water, it just provides a waterproof cover.
