We're talking about lug nuts here, not putting a Veyron engine together.A torque stick is one step better than ugga-dugga.
I’ve been doing snug + half turn…. Seems ok.
Are you secretly Project Farm? He loves those torque adapters. I understand why, load cells are pretty damn reliable and give accurate/repeatable results. I like the fact I can just grab my Clarke Pro digital torque wrench and it has my common settings in the memory. Probably my most expensive hand tool but worth it.What I've actually done is use a cheap torque wrench and then a digital adapter which goes between the socket and the torque wrench, to make sure I get it right.
My B6 Passat is pretty similar, although probably lighter and 90 ft-lbs (122 Nm) is what I torque to. My Hercules impact gun can go to over 150 ft-lbs (200 Nm) with ease, so I need to be cautious.The impact kicks back a lot more with the torque stick attached. I used the 135Nm one and my Chinesium torque wrench didn’t have anything more to add afterwards. It just clicked. So if the wrench is to be trusted, they’re torqued to at least 135 Nm now. 😅
I would still call that "within tolerance" when it comes to lugs.Most shops have impact guns with way more torque and some of them don't give a fuck. I bought the larger 700Nm Makita even though its little 300Nm brother technically is way more than enough for lug nuts, specifically because I wanted it to have enough torque for when the previous guy used all the ugga-duggas. So far it has opened everything I've asked it to without even raising an eyebrow. Money well spent.
Even a beer?
New Ryobi 30" (self-propelled) push-mower has a battery that lasts 1 hour, with a one hour charge time. So in theory, you could mow infinitely with just two batteries.
The cost per battery?
$900
Jump to 2:53:
I looked at a small snowblower last year that used the same battery packs as the drills,etc., and they were $140 each, plus it needs 2.
That's one of those tools which quite soon after buying one you simply can't remember how the hell you used to work/live without them and suddenly you find uses for it you never realised before. For me also on that list are a laser level with tripod and a plunge saw with guidance rail, should have bought them a lot earlier on in my house renovation.
The laser level was a game changer. I even brought it to my office to hang up the art on my walls so it's all neat.
Mine was actually bought for work. I would bring it to jobsites and force our furniture installers to use it, for perfect alignment (their "close enough"/"just eye-ball it" were not good enough). When we moved to a smaller office, i offered to store it at my house, since i was the one who always brought it to site. Then they laid me off, and nobody asked about it. That was...about 2 years ago now.Damn, yours is way more fancy than mine. I just have a red vertical and horizontal line.
I approve.Mine was actually bought for work. I would bring it to jobsites and force our furniture installers to use it, for perfect alignment (their "close enough"/"just eye-ball it" were not good enough). When we moved to a smaller office, i offered to store it at my house, since i was the one who always brought it to site. Then they laid me off, and nobody asked about it. That was...about 2 years ago now.![]()
