Burning temperatures:
Burning temperature LPG 1925 ?Cel
Burning temperature petrol 1986 ? Cel
Burning temperature diesel 1948 ? Cel
Compression temperatures:
Petrol engine 600 ? Cel
Diesel engine 900 ? Cel
Exhaust temperatures:
Forced induction direct injection Diesel: 800?C
Naturally aspired Petrol engine: 1050?C.
So it depends, the Diesel has a higher engine temperature, the petrol engine a higher exhaust temperature, and most likely the ticking results from heat directing metal plates in the engine to protect the engine from the exhaust heat and the exhaust itself, because as soon as your engine block ticks you are in deep shit
. Brakes tend to squeak and scream as soon as they are getting hot while being used properly (i.e. MUCH), you get that awesome burnt brake smell like the whole Nordschleife parking lot has (ask the ringmeet guys
Yes, way higher. As well, the engine block is way thicker because of the higher compression, so it takes even longer until it warms up, and the heat is directed to the indoor heating only when the engine is warm enough (a valve opens), so you freeze your ass off. That is why most modern diesels come with electric heaters to heat the cooling liquid and/or the air to the passenger room
