Oman4x4
On some of the track shoots Topgear does they have the sky fading from clear blue to black, even on a clear day... Is this a filter they use or a post-processing effect because... I like it 8)
jensked said:I think Top Gear filming is so much better than Fifth Gear filming. Really a piece of art.
bone said:jensked said:I think Top Gear filming is so much better than Fifth Gear filming. Really a piece of art.
top gear filming is better than like any other show
they really are top notch, easily blows any other motoring program awayjayjaya29 said:bone said:jensked said:I think Top Gear filming is so much better than Fifth Gear filming. Really a piece of art.
Agreed, I haven't seen many shows that can consistently top Top Gear's photography. It is fantastic.
I think it comes closer to making them look like they do. I have seen a few cars that were hideous in press photos and the like, but in person were actually pretty good looking. I think TG comes closer to this.Kip_6666 said:Though it does make the cars out to look a bit better than they do in real life, but hey, I don't mind
Maxi said:As far as I can tell Top Gear use several different filters at the same time. In alot of clips the corners of the video are darker, an effect called vingetting which is caused when several filters are mounted on top of eachother.
I'd say they are using circular polarizing filters, ND grey and graduated ND grey filters and as JC told us, color filters. I doubt they do much PP on the video, since it demands alot of computing power.
And NOTHING can replace a real filter infront of the lense, those of you who use filter plugins for photoshop, if a sky is blown out, it has no detail in it and can't be recovered. The dynamic range(detail from brightest to darkest) of digital cameras isn't large enough to have the sky and ground exposed correctly. Adding a grad ND filter in at PP won't give you more detail in the sky, it might give a little, but it is in essence a local contrast fix. The only real way to achieve the effect is by using a real filter.
