Top Gear S16 E02 720p (by FOV) Conversion problem
Eaglegt
I downloaded this ep as usual, used same prog - convert X to DVD to burn to dvd, did same with ep 01 ( as with all my avi burns) but this time recieved error message,
''estimated duration of the video was inaccurate. output size may differ from target size.''
it burnt only the menu and TG start up screen to the dvd.
No changes have been made to the converter/burner since the successful s 16 ep 01 ( and the two specials 720P ) 720P burn.
I'm at a loss to find the cause, is there a problem with the 720P FOV version?
apparently there is considering the two other threads on the issue.
something changed with the audio encoding.
