Topgearfanatic
is a Queen
It's simple imagine a 21 speed bike: If you're in gearing 1:1 for every 1 pedal push you go forward a little but in gearing 1:7 you go forward more. it's simple, maybe to the more engineer put mind it is.
Here's the simplest explanation: Horsepower makes you go fast. Torque makes you feel like you are going fast; it gives you that kick in the back when you push the gas.
/thread
Agreed, even though I know what torque is, metric system would be better..
Twerp128
The transmission doesn't have anything to do with the hp an engine produces when understanding torque and horsepower.
Torque is the actual power produced by an engine, horsepower is how quickly an engine can utilize it's available torque. That's all you need to know to basically understand torque. After that you get into power-bands, and engine design, transmission and differential stuff, etc.
Noodle
hey, my car has the exact same hp/torque figures as you! go you!
Torque is the effectiveness to turn an axis, or twisting force. It has NOTHING to do with acceleration.
This is something that has been a topic on every car forum on the entire internet, and it really isn't that complicated but many people have it wrong. Many people say "Torque is what wins races" but it doesn't necessarily. Semi trucks (same as a lorry) usually make about 1500 lb/ft of torque, but they're still slow, even if not pulling anything. Locomotive engines make upwards of 8000 lb/ft of torque, but they're slow as well. Rocket engines are very fast but have no measurable torque.
When figuring torque, there is no component of time. Horsepower is figured with time as a component, and is relevant to acceleration. The fact of the matter is that you need enough torque to effectively move the car, but horsepower is what makes you go fast.
Just because it has more torque does not mean it will be faster. Torque is a measure of power. Horsepower is a measure of power/time.First of all, yes it does. The harder you twist the axle, the harder the car will accelerate.
Forget drivelines and gearing and take for instance two engines that both have 300 ft/lbs. of torque. One engine is of poor design and due to this the engine revs very slowly, however it still produces 300 ft/lbs. of torque. The second engine is sleeker and more efficient therefore it is able to reach it's maximum power very quickly even though it creates the same amount of power as the slower engine.
Stroke vs. Bore effects is most influential in how fast a given engine revs, along with weight (especially unsprung weight), and resistance.
For an extreme example I believe modern F1 engines only produce between 200 and 300 ft/lbs. of torque, however the engine is able to exert it's torque extremely quickly, thus they have double or triple the amount of horsepower as torque. A Porsche boxer engine may offer the exact same torque as an F1 car, but due to a less focused, engine design it can't exert it's torque as fast as a F1 car. Torque does not effect how fast an engine revs, it is the extreme basic measurement of how much work an engine is able to do.
^Yeah I think we are.
