Dr_Grip
Made from concentrate
- Jul 8, 2008
- Location
- Germany
- Car(s)
- 1979 Opel Kadett | 1972 Ford Country Sedan
So now i got my engine back in the Kadett, it runs just fine, but...
When i press the clutch, the engine cuts out. I can start the engine in neutral and, while on a platform, with the wheels in the air, i can also start the engine with a gear engaged. The drive shaft and one wheel then turn just as expected. But when i press the clutch pedal, the engine cuts out. When i press the pedal i can literally feel how something stars braking the engine, bringing revs down. When pressing the pedal fully, the engine just cuts out.
I already took the clutch assembly apart and checked that the clutch disk is in the right way round, which is is. I can't see any scratches or stress marks on the outside of the plate spring or on the clutch lever....
