Carsightings
i know the bigger the capacity the better the horsepower and torque ouput but what does the litre bit mean? i hope you understand my question
Carsightings said:where is it from?
jensked said:what I don't understand is the relationship between volume and bhp. the more liter, the more bhp? how does that work?
Girl.....checkmgkdk said:The thing I wrote? It's from my head
BerserkerCatSplat said:Another way to increase HP is to increase what's called the "compression ratio" of the engine.
The "compression ratio" of an engine is basically how much it compresses the air/fuel mixture before combustion.
Let's say you have a 8L V8 engine. That means that each cylinder's combustion chamber is 1L in size at the bottom of the piston stroke (aka Bottom Dead Center). Now, if the piston moves upwards to the top of its stroke (Top Dead Center) and the size of the combustion chamber has been reduced to 0.1L, you can say that the engine has 10:1 compression, as the compressed mixture is one tenth the size of the uncompressed mixture.
Most engines run about 8-9:1 compression, but the more compression you run, the more power you get from the same amount of air&fuel. However, high compression is very hard on engines and can lead to detonation.
* 1,000 horsepower is equivalent to roughly 2.6 billion joules per hour. A gallon (3.8 liters) of gasoline contains 132 million joules, so a 1,000-hp engine has to be able to burn just over 20 gallons of gasoline per hour.
* However, car engines are only about one-quarter efficient -- three quarters of the gasoline's energy escapes as heat rather than as power to the wheels. So the engine actually has to be able to burn at least 80 gallons per hour, or 1.33 gallons (5 liters) per minute.
* Let's convert over to metric. Gasoline requires about 14.7 kilograms of air to burn 1 kilogram of gas. Air weighs 1.222 kilograms per cubic meter at sea level. A gallon of gasoline weighs 2.84 kilograms. So the engine has to be able to process 2.84*1.33*14.7 kilograms of air per minute, or roughly 45 cubic meters of air per minute. That's 45,000 liters of air per minute.
* If a V-8 engine is turning at 6,000 rpm, it can inhale a total of 24,000 cylinders' full of air per minute. If it needs to inhale 45,000 liters of air per minute, it works out to roughly 2 liters per cylinder-full. That's a 16-liter engine.
We need a 16-liter engine to burn 1.33 gallons of gas per minute. That actually makes sense -- the engine in the Dodge Viper is 8.0 liters in displacement and produces 500 hp.
YF19pilot said:BerserkerCatSplat said:Another way to increase HP is to increase what's called the "compression ratio" of the engine.
However, detonation -- or knocking -- can be circumvented by running higher grades of gasoline.
YF19pilot said:You know, maybe we should sticky this thread and direct people who are unfamiliar with automobiles and their workings to this thread, sort of like an unofficial faq about cars.
However, detonation -- or knocking -- can be circumvented by running higher grades of gasoline. The grades or ratings of gasoline are a referance to the ability of the gasoline to not prematurely detonate when compressed. That's why high end sports cars require high end fuel. If you were to put 87 into a Ferrari, you'll probably end up with a $200,000 paperweight...
Yes, Beserker, I realize you probably already know this, but this is more for the education of others who are unfimilar with auto termanology...
bone said:YF19pilot said:You know, maybe we should sticky this thread and direct people who are unfamiliar with automobiles and their workings to this thread, sort of like an unofficial faq about cars.
there have already been a few threads about that made
i tried to explain superchargers: http://forum.finalgear.com/viewtopic.php?t=1760&highlight=
i had a question about diesel engines, and later found a super read about them: http://forum.finalgear.com/viewtopic.php?t=1747&highlight=
a superb read about rotory engines: http://forum.finalgear.com/viewtopic.php?t=8265&highlight=
a thread about a 6 stroke engine (and some others): http://forum.finalgear.com/viewtopic.php?t=8268&highlight=
josty explaining turbos: http://forum.finalgear.com/viewtopic.php?t=1744&highlight=
josty had a question about diffs, and i tried to explain (agian): http://forum.finalgear.com/viewtopic.php?t=1900&highlight=
we need more discussions in this direction
much more interested in stuff like this than what brand released which car
