I just got an engine from a friend that I would like to get freed up. It has been sitting outside for about twenty years, and part of that time it was covered, but that didn't last long. It doesn't have a carb on it and I am sure that by now anything that was put into the cylinders has drained out. This is not a valuable engine, but there is some sentimental attachment and that is why I would like to save it. This will not take place anytime soon, it is to damn cold, and the engine nearly stayed there because of it, but he is selling the house and he plowed a way to it.
I will be removing the plugs and draining anything left in there out(may even need to pull the heads), and at this point I am thinking some trans fluid mixed with acetone is a good first attempt. I will also be using an impact (set on low, with low air) on a flywheel bolt (or few) to help break up the corrosion(not turning it over). The only thing I can think of that would be better is one of those corrosion removal products, but I am not sure I want to drop that kind of money into it unless it is a sure thing. Option 3 being take off what I can and have it boiled at the machine shop.
Any comments would be appreciated.
