Jostyrostelli
- May 29, 2004
and adding power when you want to stop = no good.
When would that happen? Brake and gaspedal pressed at the same time?
Renesis said:All brake tests are done to get the best results and guess how they do? they use the brake and clutch, no gear change
SiR_dude said:People, face it: using the engine's backpressure to help brake is a practical thing. The quickest, but not safest, way to stop is to lock the brakes, and stop the wheels completely. Done.
I definitely hope soJostyrostelli said:SiR_dude said:People, face it: using the engine's backpressure to help brake is a practical thing. The quickest, but not safest, way to stop is to lock the brakes, and stop the wheels completely. Done.
I assume you are joking now....?
Cubits said:Hit the brakes hard, dip the clutch, downshift two gears and let the clutch out... tell me if it becomes unstable...
v0od0o said:I definitely hope soJostyrostelli said:SiR_dude said:People, face it: using the engine's backpressure to help brake is a practical thing. The quickest, but not safest, way to stop is to lock the brakes, and stop the wheels completely. Done.
SiR_dude said:v0od0o said:I definitely hope soJostyrostelli said:SiR_dude said:People, face it: using the engine's backpressure to help brake is a practical thing. The quickest, but not safest, way to stop is to lock the brakes, and stop the wheels completely. Done.
I'm hoping someone will try it and make a video of it
Locking the wheels up works for the first few seconds, or less. Then the rubber heats up and becomes soft. All of a sudden there's less friction (and you're not decelerating as much), and as someone already mentioned, the tread blocks move, and stuff gets really messy. And there's a LOT of smoke.
Stopping very quickly, especially from high speeds, is an art that racing drivers know best. It involves precise timing, and a good knowledge of the car you are driving. Using the engine to help you is an option, but not always the best. If you slam your brakes to hard, they will heat up, and I'm sure you all have heard of "brake fade", not to mention what was already discussed about the tires.
Point in question: Don't get yourself into a situation where you need to stop faster than you can.
Wasn't it to allow for steering control during hard braking?Jostyrostelli said:Why do you think ABS was invented? To let cars brake more efficient.
ESPNSTI said:Wasn't it to allow for steering control during hard braking?Jostyrostelli said:Why do you think ABS was invented? To let cars brake more efficient.
logo said:people here don't know anything about driving
