plus, i can't stop recommending my case (which i actually bought after seeing someone else on here buy it ): Fractal Define R2
I have that too. It's really nice for it's price. But you do want a modular PSU with it.
yes indeed you do... mine isn't, it was rather a pain hiding away all those cables nicely
Just go ahead and double your RAM, that'll make the biggest difference. When you work with images in photoshop they're completely uncompressed so they just suck up RAM. If you're on Vista or 7 then 2 gigs is barely enough anyways.
And are you running photoshop in 64 bit? If not you should be, if you are then keep on trucking.
Also, like Windows, Photoshop uses a swap file. If you have both the Windows page file and the Photoshop swap file on the same drive it can slow things down. However, as far as hardware is concerned I would agree that more memory is the immediate fix.
I'll look into some RAM then (Although I am running on XP). Oh, and how would I check if Photoshop is running in 64 bit or not?
They're on the same drive, so maybe I should try moving Photoshop to my second hard drive?
Photoshop will only run in 64bit if you have a 64bit O/S. So, if you have XP 64bit then you're set. Chances are you're on 32bit. Not many people used XP 64bit. If that's the case you're limited to 3.25GB of memory. You could put as much as your system board can take but a 32bit O/S can only address 3.25GB. Perhaps you could pick up Windows 7 64bit, some more RAM, and move the PS swap file to another drive.
However, you will need to make sure you have a 64bit CPU first.
You don't have to install PS to another drive. You can just tell it where to put the swap file. I believe you can change where it is in edit, preferences, plug-ins & scratch section.
so basically what you want, is pretty much exactly the PC viper recently bought
maybe just have a browse around for his thread and see if what he bought will suit your needs.
if i remember correctly it was:
core i5-750 (yes it's actually a quad)
gtx470
8gb
and that lovely asus P7P55D-E with USB3 and SATA 6Gb
rest of the parts would have to be tailored to your needs i guess
EDIT: viper's original thread would be here and then here is what he bought as far as i can work out...
This is what I have so far, note that microcenter has an i7-930 for $100 less I'd probably go with that instead. I'm also lacking a case (the one you linked to is nice, but I don't see it for sale in the US) and power supply. I haven't had time to look into SSDs or what the current crop of TV tuners are (Yay working 18 hours this weekend).
I don't think I quite need the graphics performance Viper got, but the minor price difference may make it a poor choice not to step up.
I'm currently using Jolicloud and Ubuntu 10.01. Linux has really moved on in the two years since I last took an interest in it!
!! be aware when using socket 1366 !! ==> you get a triple-channel RAM setup! so you want to get a 6GB Kit (3x2GB) when going that way (or two of those... to go over the top ^^)
also, be careful when buying RAM like the one you have in your list: the heatspreader is ridiculous and might just be in the way in case you decide to get a decent CPU cooler.
next up the GPU: i don't think a 9800 is a great choice... in that price-region i'd go ATI (5770 maybe). nvidia stuff isn't really all that interesting there for me
SSD: there are quite a few people on here who have them... i think the intel X25 are quite good, but i'm not reaaally too sure on those.
ah, with HDD's: if you get an SSD large enough to hold your OS, programs and games, you might think about getting one of those "storage" HDDs like the WD EARS series (caviar green they're called?)... they'll be quieter and cooler
for a PSU: just get yourself something modular! agagagagag i can't stress that point enough. it was so annoying to tie all my cables away into some corner of the case so they're not in the way all the time... i'm angry at myself for not just paying the 5 extra bucks. also, i can really recommend enermax PSU's... never had any problems and they're awesomely quiet and efficient (think modu82+ series or something), although quite expensive.
finding a nice case can be a major pain in the ass. i searched for ages because i was looking for something clean and not too flashy. i'd have loved a lian li, but they're ridiculously expensive most of the time (at least the interesting ones are ). but maybe lancool or whatever that brand's called have something you might like? (they're sort of the lian-li cheap-brand or something).
/snip
You should be able to reinstall Vista and re-upgrade to 7 no?
Duly noted and good to know. I had an old desktop with RDRAM that had to run in pairs or with some little jumper thing in empty slots a while ago, so the funny ram thing isn't a hassle. Now, since it has to be installed as multiples of 3 sticks, could I also add an additional 3GB via 3x 1GB sticks to the 3x 2GB sticks for a total of 9GB if I wanted?
I loooooove my new mouse.
Edit: Looked up the CPU, Intel's site says it's 64-bit. Also, I switched the location of the swap file to my other hard drive.
