Do you have any other controllers that you could connect to it in the meantime via Bluetooth or dongle to hold you over until the cover is available?Okay, I've had this for a few days now and I do like it, but, and it is a big but, it is not comfortable for me to use for more than 90ish minutes. If I play GTA V, it is about an hour. After that, I am done for several hours.
This is a me problem and I knew this might happen from the start. I am the guy that really liked the original Xbox Duke controller. I have suffered since it got cancelled.
I already planned on getting the Dbrand Killswitch cover so I could have bigger grips, but they still have it listed only able to reserve. No other cover looks nearly as good.
So I might sell the Steamdeck and possibly build a new PC.
Maybe this is a DBrand Killswitch alternative.
ModCase for Steam Deck PC0104
【Complete and flexible】This accessory consists of a protective back case with its own metal stand, a strap to attach other accessories, and a front cover to use when the Steam Deck is idle. 【Perfect Fit】The modular case cut-outs are perfectly aligned with the handheld’s output/input ports...jsaux.com
It's just a plastic case right? I don't imagine it can collect any data?
Then it's just name and email? A lot of companies do that. If you pay with credit card they probably can't share any of that if they are following PCI rules.The case doesn't, but jsaux does.
