lip
Stamping cars. A new trend? :lol:
Anyway, Spectre, I hope the way the other driver cut you off plays a rule in the outcome.
He needs a hitch cover with a raised FG logo on it.Stamping cars. A new trend? :lol:
Ha well it would've been pretty funny in that wreck anyway. Both in terms of carnage and the potential innuendos.
Why do you have a bale spike though? Tryin to get in on that super lucrative part-time ranch hand work?
Der Stig thinks I should have kept it and welded it on the front of the truck.
Looks like your truck was a road hazard in 1996.
Looks like it isn't much better now. :lol:
Der Stig keeps telling me I should have welded the hay spike to the front instead.
Turn that big Ford into the mighty hand of vengeance, sent down to strike the unroadworthy! :lol:... just flip the fucker back, and let's go to yard..
Do you think you will own that truck in another 20 years to see if it has lasted as long as the original?
The aftermarket replacement one has a rubber gasket, the tower shroud (of a rather more flexible plastic than the original) then another rubber gasket to seal it to the body.
Of course, it has to drive over there first...
Can't you just order from RockAuto or don't they ship to Russia?I'm about to loose my brakes due to all kinda leaks from master cylinder & vacuum whispering "die ssssoon" every time i touch the pedal, so... i'm scearching for a replacement and they are 'round $300-400 here. (for whole thing)
What i find most amusing here is that foam piece around the rod. Gives sense of "quality" after the old empty cover.
& what's wrong with using that ball joint you mentioned coupe posts ago?
P.P.P.S. Howmuch was the booster for you?
