I'll look through and if any bushes are worn then I'll replace with poly ones, but I'll leave a complete overhaul until I'm earning. The braces are easy to mount and still need to be done. Not sure but are swaybars the same as anti-roll bars? I'll be doing the piggy back ARB mod since its cheap.
Also looked through the history and found a complete gearbox rebuild at a cost of ?1300 in 2009
I've got history from the previous owner back to about 2008, unfortunately, and nothing before that other than the service book which has been regularly filled out. One of the service 'notes' in the book in 2008 at 75k miles states 'New Turbo Fitted' so I think I might call round the garages and see if they'll tell me anything about what they've done to the car other than normal services.
Other receipts state new NS Track Rod ends and all new breather hoses in 2011, front OS anti-roll bar link (2010), two new front NS wheel bearings (both 2009 in Feb and Dec) and new front brake discs/pads in 2009.
The only other concern is the most recent receipt from 2011 is a checkup on a 'customer concern' - "Report excessive play/lift in both drive shafts indicatoring possible wear in differential side bearings". Only cost him ?35 to have it checked out so clearly no work was done, but I don't know how much that would cost to fix. Strangely its not an advisory on the most recent MOT (after that receipt).
Doing an MOT history check shows its all fine apart from 2011's MOT with advisories of small chips on windscreen, tyre wear, insecure gear nob (it spins round but doesn't lift off
) and 'oil leak' (very helpful). But 2012's MOT only had one advisory; Front exhaust noisy. Go back to 2009 and a service receipt has 'Advise: Exhaust manifold gasket is blowing' written on it - so maybe that's been an 'issue' since 2009 but none of the other MOTs cared...? This confuses me
